Hello,
When I load an EPICS example application to the vxWorks5.5.1
running on a MPC8572 CPU board, "Undefined symbol" is reported as
follows,
ld <bin/vxWorks-mpc8572/example.munch Undefined symbol:
clone__Q2t12basic_string3ZcZt18string_char_traits1ZcZt24__default_alloc_t)Undefined
symbol: __tf9exception (binding 1 type 0) Undefined symbol: _vt$9bad_alloc
(binding 1 type 0) Undefined symbol: __cp_push_exception (binding 1 type
0) Undefined symbol: __tf9bad_alloc (binding 1 type 0) Undefined symbol:
unexpected__Fv (binding 1 type 0) Undefined symbol: __uncatch_exception
(binding 1 type 0) Undefined symbol: __tfv (binding 1 type 0) Undefined
symbol: _t24__default_alloc_template2b1i0$_S_free_list (binding 1 type
0) Undefined symbol: __rtti_user (binding 1 type 0) Undefined symbol:
__rtti_si (binding 1 type 0) Undefined symbol: _$_9bad_alloc (binding 1 type
0) Undefined symbol: __check_eh_spec (binding 1 type 0) Undefined symbol:
__get_eh_context (binding 1 type 0) Undefined symbol: __sjthrow (binding 1
replace__t12basic_string3ZcZt18string_char_traits1ZcZt24__default_alloc_t)Undefined
symbol: terminate__Fv (binding 1 type 0) Undefined symbol:
_t12basic_string3ZcZt18string_char_traits1ZcZt24__default_alloc_template2)Undefined
symbol: _vt$13runtime_error (binding 1 type 0) Undefined symbol:
__start_cp_handler (binding 1 type 0) Undefined symbol:
_t24__default_alloc_template2b1i0$_S_node_allocator_lock (binding 1 type
)Undefined symbol: __cp_pop_exception (binding 1 type 0) Undefined symbol:
__ti9exception (binding 1 type 0) Undefined symbol: _vt$9exception (binding 1
type 0) Undefined symbol: __builtin_vec_new (binding 1 type 0) Undefined
symbol: __eh_rtime_match (binding 1 type 0) Undefined symbol:
__builtin_vec_delete (binding 1 type 0) Undefined symbol: __rtti_class
(binding 1 type 0) Undefined symbol: __builtin_delete (binding 1 type
0) Undefined symbol: __terminate (binding 1 type 0) Undefined symbol:
__builtin_new (binding 1 type 0) Undefined symbol: _vt$11logic_error (binding
1 type 0) Undefined symbol: __eh_alloc (binding 1 type 0) ld error: Module
contains undefined symbol(s) and may be unusable.
Checking the vxWorks
image, it indeed does not include these symbols. And use "grep -r" to check the
gnu library on the vxWorks host, the library files libcplus.a and
libgnucplus.a under Tornado2.2/target/lib/ppc/PPC403/gnu, PPC405/gnu,
PPC440/gnu, PPC603/gnu, PPC604/gnu and PPC860/gnu do provide these symbols,
but the libcplus.a and libgnucplus.a under Tornado2.2/target/lib/ppc/PPC85XX/gnu
directory do not provide, which seems to cause the above
error.
Do you have encountered such a problem before?
Lin Wang
- Re: Problem when loading epics3.14.12.1 application to vxWorks5.5/MPC8572 Dirk Zimoch
Re: EPICS Modbus module + PLC Pavel Maslov
<2013>
Re: Race condition during IOC startup? Andrew Johnson
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
