Hi all,
I have a few soft iocs I'm running on a linux box running SL
2.6.18... My epics
version is 3.14.11. I have a similar configuration for another
control system elsewhere.
Because I have multiple servers on a single processor, I generally
assign them different
ports (initially set up by a former colleague). The ports I'm using
are 6721, 6722, 6723,
and 6724. The firewall is not set up on this machine, so I don't
know if there is something
else that I should be doing in the configuration.
When I run my iocs, I get a lot of CA beacon errors when I run my
iocs.
../online_notify.c: CA beacon (send to "148.79.117.13:6724") error
was "Connection refused"
../online_notify.c: CA beacon (send to "148.79.117.13:6722") error
I've spent a lot of time reading the CA manual and looked through
techtalk and haven't
found a definitive solution to fixing this. I'm under the
impression that I need to set the
beacon environment variable, but to what?
Pierrick
"Whether you think you can or think you can't, either way, you are
correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-79-48-860-197 (US/UK mobile)
- RE: CA beacon question Hill, Jeff
caClient with PCAS pthomas
Re: caClient with PCAS Xiaoqiang Wang
<2013>
Re: caClient with PCAS pthomas
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
