Hi Ralph,
Thanks for the response. I suppose that I'm being a bit thick, but
I'm not able to understand
your instructions. In starting the gateway, I added the flag
"-debug 50". I cannot connect
from my remote machine 333.33.33.33; I've attempted caget with hopes
that the log file
on the gateway machine will show some attempt to connect, but to no
avail. If this is not
what you mean, would you please be more specific?
Pierrick
On 02/20/2013 11:27 AM, Ralph Lange wrote:
On 20.02.2013 18:09, Pierrick Hanlet
wrote:
Hi
all,
I'm running an epics gateway v2.0.4 on a linux box running SL
with kernel 2.6.18 and is part of a LAN;
my EPICS version is 3.14.11. We have established an external
connection to this subnet with a DSL
connection with a public IP address and an ethernet cable from
the DSL modem. I have no name for
this public IP address.
So, my questions are:
1) How do I set up my gateway.access file?
2) On my remote node, how do I define my EPICS_CA_ADDR_LIST?
3) Can I even use an IP address in the access file?
Let's say that my host computer running the gateway is
111.11.11.11, the public IP address is 222.22.22.22,
and my remote machine on which I want the EPICS data is
333.33.33.33.
I've tried a variety of things and I'm clearly missing
something. On my other uses of the gateway, I don't
have the intermediate hop over the AT&T provided public IP
address.
Pierrick
Hi Pierrick,
I would say for the remote client
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_CA_NAME_SERVERS= 222.22.22.22
On the gateway, I would turn up debugging, connect from the remote
client, and check what it provides as user and host. These will be
the values to use in the Access Security configuration.
Good luck!
~Ralph
"Whether you think you can or think you can't, either way, you are
correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-79-48-860-197 (US/UK mobile)
- Re: gateway: strange configuration Martin L. Smith
- Re: gateway: strange configuration Ralph Lange
- gateway: strange configuration Pierrick Hanlet
RE: Best practices for introducing new dot releases of modules. Shankar, Murali
Re: trying to compile snmp for Wiener PL512 crate application James F Ross
<2013>
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
