Hi Bruno,
On 2013-02-07 Bruno Santos wrote:
> Does anyone have any portable channel access examples in C++?
> How I can get the last version of pcas c++?
The PCAS is provided as part of EPICS Base (under src/cas); the latest version
is the one that was shipped with the recent Base 3.14.12.3 release, which
added support for DBE_PROPERTY events (caServer::propertyEventMask()).
Once you have that installed you can use the makeBaseApp.pl script to create
an instance of the caServer template which provides a couple of example server
programs. Others here should be able to point you to some more complex
examples if you want them.
HTH,
- Andrew
There is no such thing as a free lunch. When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
- Portable Channel Access C++ Bruno Santos
Re: [CSS] the tab widget's active tab Pavel Maslov
<2013>
support module for Xspress 3 matthew.pearson
<2013>
