1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: scan thread suspended - solved
Date: Tue, 29 Jan 2013 16:16:23 +0100
Hi Bob,
> Whichever record is locked is the one that was processing when it suspened.
> Is this a linux IOC? I am only familiar with vxWorks - you can to a
> tt "taskid"
> and it will give you a task trace.
That pointed in the right direction. I'm on Linux so I attached the
debugger and created a stack trace of all threads. This resulted in a
perfect hit: An assert() in my device support caused the thread to suspend.
Thanks for your help,
Martin
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel.: +49-6151-16-5121
Fax: +49-6151-16-4321
scan thread suspended Martin Konrad
Prev: Re: scan thread suspended Martin Konrad
Next: RE: BOY number representation & display scaling Chen, Xihui
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Save/Compare/Restore Application Emmanuel Mayssat
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
