1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: unable to tunnel CA through ssh tunnel
To: [email protected]
Date: Mon, 28 Jan 2013 09:22:30 -0500
Greetings everyone,
I'm trying to do something rather simple but can't seem to get it to work.
What I'm trying to do is the have my CA client to connect a CA server
via a SSH tunnel.  The CA client is running on a Windows system, and the
SSH tunnel is created using Putty.
Creating the SSH tunnel for port 5064 between the server and client,
using PUTTY, seems to work fine.
Then I set my Windows environment to have the following (as documented
at http://www.aps.anl.gov/epics/base/R3-14/12-docs/CAref.html#Environmen):
EPICS_CA_NAME_SERVERS=<localhost_ip_address>:5064
EPICS_CA_ADDR_LIST=
EPICS_CA_AUTO_ADDR_LIST=NO
Then when I try to access one of my PVs using the CA client, I get the
following error message:
>      C:\program files\EPICS Windows Tools>caget motorController:TestBox_1:C1
>      CA.Client.Exception...............................................
>          Warning: "Empty PV search address list"
>          Source File: ..\udpiiu.cpp line 359
>          Current Time: Fri Jan 25 2013 16:30:15.057180376
>      Channel connect timed out: 'motorController:TestBox_1:C1' not found.
At this point I'm not sure if any traffic is actually going through the
SSH tunnel or not. :-|
Is a second tunnel for port 5065 also required?
Anyone managed to get a similar setup working?
Any information about this would be much appreciated.
  Andre
André Charbonneau
Research Computing Support Analyst
Shared Services Canada | National Research Council Canada
Services partagés Canada | Conseil national de recherches Canada
100 Sussex Drive | 100, promenade Sussex
Ottawa, Ontario  K1A 0R6
Canada
[email protected]
Telephone | Téléphone:  613-993-3129
Re: unable to tunnel CA through ssh tunnel (SOLVED) Andre Charbonneau
Re: unable to tunnel CA through ssh tunnel Till Straumann
Prev: RE: Can't read MIME Types file Kasemir, Kay
Next: Re: unable to tunnel CA through ssh tunnel (SOLVED) Andre Charbonneau
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
