On Tuesday, January 22, 2013 15:31:02 James F Ross wrote:
> It seems to be going running the program relating to the
> eemc (one of the early ones called by a seq command in the st.cmd file) but
> never moves on to the program after it. There is no indication of error,
> but I'm looking at both the eemc source code and the bemc code (the next
> program called in the st.cmd file).
Which release of seq are you using? This sounds a bit like a known problem
with one of the earlier releases in the 2.1 series (see http://www-
csr.bessy.de/control/SoftDist/sequencer/KnownProblems.html#known-problems-in-
release-2-1-6).
When building, check that whenever snc is executed it does *not* have the '-i'
switch passed. If it does, search your Makefiles and remove '-i' from SNCFLAGS
definitions.
If you are using a release later than 2.1.6 this does not apply.
Instead of checking all PVs you programm variables are assigned to (as has
been suggested), you could play around with the -c flag to snc, at least to
make sure that missing PVs are really the cause of your problem (with -c the
programs start w/o waiting for connections; this may mean they will not work
correctly but at least you should see them running with seqShow).
Cheers
Ben Franksen
() ascii ribbon campaign - against html e-mail
/\ www.asciiribbon.org - against proprietary attachments
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
- sequencer programs in an IOC James F Ross
- RE: sequencer programs in an IOC Mark Rivers
- Re: sequencer programs in an IOC James F Ross
RE: DXP ElapsedRealTime Mark Rivers
Re: sequencer programs in an IOC Kevin Peterson
<2013>
Edm installation Steve
<2013>
