For my system (Debian 6, 64bit), I installed the following packages
libxt-dev libmotif-dev x11proto-print-dev libxmu-headers libxp-dev
libxmu-dev libxmu6
by using the aptitude command
aptitude install libxt-dev libmotif-dev x11proto-print-dev
libxmu-headers libxp-dev libxmu-dev libxmu6
for my MEDM installation. I hope it will help if you are using Debian
based distributions.
Jeong Han
On 01/10/2013 05:19 PM, Hinko Kocevar wrote:
We seen this problems too with newer Ubuntu and Mint Linux distros
(other might apply too).
I think that the root problem is in the fact that "multiarch" is
supported out-of-the box on the newer versions of Linux distros. In
other words, static and dynamic libraries for certain packages (mostly
X11) end up in the /usr/lib/i386-linux-gnu folder (or similar) instead
of in the /usr/lib folder (where EPICS looks for them).
We solved the problem by making a soft link like this
ln -snf /usr/lib/i386-linux-gnu/libXt.a /usr/lib/libXt.a
Note the full path!
I would like to see more friendly solution in the future for this issue.
Thank you!
Hinko
On 01/10/2013 04:18 AM, Kate Feng wrote:
One need to install the libxt-dev package, too for the development
header.
Also, depending on your build config, one might need to provide the
link
from the medm source tree directory/lib
ln -f -s /usr/lib/.../libxt.a libXt.a
Cheers,
Kate
On 01/09/2013 09:58 PM, Mark Rivers wrote:
You need to install the libXt package on Linux.
behalf of D Peter Siddons [[email protected]]
Sent: Wednesday, January 09, 2013 8:38 PM
To: [email protected]
Subject: medm build
I just tried to build medm 3_1_7 using epics base-3.14.12.2 on Ubuntu
12.04. It gives an error:
*** No rule to make target `/usr/lib64/libXt.a', needed by `medm'.
I suspect a configuration error. Any suggestions?
Pete.
D. Peter Siddons
Detector Development Group Leader
NSLS, Bldg. 725D
Photon Sciences Directorate,
Brookhaven National Laboratory
Upton, NY 11973
email: [email protected]
Phone: (631) 344-2738
Jeong Han Lee, Dr.rer.nat.
Accelerator Division
Rare Isotope Science Project
Institute for Basic Science
70, Yuseong-daero 1689-gil, Yusung-gu,
Daejeon 305-811, South Korea
cell : +82-10-7363-2083
tel : +82-42-878-8733
fax : +82-42-878-8799
- medm build D Peter Siddons
- RE: medm build Mark Rivers
- Re: medm build Kate Feng
Re: medm build Hinko Kocevar
Extensions installation for newbie Michal Vítek
<2013>
acalcOut Pavel Maslov
<2013>
