On Thu, Nov 29, 2012 at 9:07 PM, J. Lewis Muir <[email protected]> wrote:
> On 11/29/12 12:30 PM, Shankar, Murali wrote:
>> Just wanting to check if anyone uses CAJ (pure Java CA client) clients in production especially in combination with IOC's that are using the native CA library.
>> I've pinged a few folks offline; however, it was thought that a community wide repoll would probably be beneficial.
> Hi, Murali.
> We use it in production with IOCs using the native CA library at
> IMCA-CAT (Sector 17 at the APS).
> I suspect NSLS-II uses it since they indicated a commitment to ensure it
> is maintained back in March of 2009:
> http://www.aps.anl.gov/epics/tech-talk/2009/msg00544.php
>> Known issues that I am already aware of (thanks Michael and Eric)
>> 1) Interoperability issue with the CA Gateway and clients using monitors with DBE_PROPERTY.
> It took almost three years, and I haven't tried using it, but the CAJ
> Changes page shows version 1.1.10, released on 2012-06-14, with a
> description of "DBE_PROPERTY support". Is your problem that it seems
> CAJ doesn't support the DBE_PROPERTY event type, or is it a problem
> specific to using DBE_PROPERTY with the CA Gateway?
Yes, JCA and CAJ where added DBE_PROPERTY support.
> Do you know where the problem lies? Have you filed a bug report with
> either project?
> Checking the CAJ web site, it seems there is no bug tracker set up for
> CAJ; you have to send an email. I think CAJ is big enough and used by
> enough people that a bug tracker is warranted. Matej, would you be up
> for enabling a bug tracker for CAJ?
Since JCA/CAJ are hosted as SourceForge project it's easy to enable
bug tracker feature.
Here it is: https://sourceforge.net/tracker/?group_id=336891
>> 2) For CA Access Security, CAJ uses full hostnames (with domain) and libca uses short host names (without domain)
> This sounds like a bug to me. I would expect the two to behave
> identically. I don't know what the correct behavior is. Maybe libca is
> not behaving in accordance with the spec, or maybe the short hostname is
> according to spec. If the latter, and if Matej (the developer of CAJ)
> does not want to change this behavior as the default, perhaps support
> could be added for a compatibility-mode option/property to enable the
> use of the short hostname in CAJ?
The method CAJ uses to get hostname is (or was in 2006) not
deterministic - it can return long or short name. There is an JVM
"-DCAJ_STRIP_HOSTNAME" option to strip SHN from possibly returned FQDN
(e.g. alma.hq.eso.org -> alma).
>> To clarify, a monitor won't clear in CAJ without an explicit IO flush. In JCA/JNI, the monitor will clear without the IO flush, so the behavior is different.
> Hi, Tom.
> I didn't know about this; thanks for reporting it. Does Matej know about it?
No. Thanks.
(It's super easy to "fix")
Matej
- Re: Using CAJ in production J. Lewis Muir
- Using CAJ in production Shankar, Murali
Re: Using CSS and setting up RDB Archiver Kasemir, Kay
<2012>
<2012>
