Hi Shankar,
On Diamond Beamlines our primary EPICS client is GDA, which uses the CAJ pure Java CA client. However, if I understand you correctly, they
probably don’t monitor PV’s with DBE_PROPERTY through a CA gateway.
they don’t use CA Access Security
I am not sure about the issue with EPICS_CA_MAX_ARRAY_BYTES, but they do get and monitor large arrays.
Cheers,
Nick Rees
Principal Software Engineer Phone: +44 (0)1235-778430
Diamond Light Source Fax: +44 (0)1235-446713
Just wanting to check if anyone uses CAJ (pure Java CA client) clients in production especially in combination with IOC's that are using the native CA library.
I've pinged a few folks offline; however, it was thought that a community wide repoll would probably be beneficial.
Known issues that I am already aware of (thanks Michael and Eric)
1) Interoperability issue with the CA Gateway and clients using monitors with DBE_PROPERTY.
2) For CA Access Security, CAJ uses full hostnames (with domain) and libca uses short host names (without domain)
3) The issue with EPICS_CA_MAX_ARRAY_BYTES has already been fixed.
Has anyone encountered any issues/differences on the IOC side?
Murali
