No, I don’t think that will fix it, because you have not increased NORD. Any clients that use the new EPICS feature of subscribing to callbacks with a length of zero only receive NORD elements in the callback. So the string they receive
won’t be Nil terminated, even though the waveform record itself is now Nil terminated.
But you can’t increase NORD in devAsynOctet, because that device support must also be able to handle binary byte arrays, and increasing NORD would mess that up.
Would this fix things?
--- devAsynOctet.c 2012-06-25 15:20:07.000000000 -0700
+++ devAsynOctet.c.proposed
2012-11-12 12:55:29.000000000 -0800
static void callbackWfRead(asynUser *pasynUser)
devPvt *pdevPvt = (devPvt *)pasynUser->userPvt;
waveformRecord *pwf = (waveformRecord *)pdevPvt->precord;
status = readIt(pasynUser,pwf->bptr,pwf->nelm,&nBytesRead);
- if(status==asynSuccess) pwf->nord = nBytesRead;
+ if(status==asynSuccess) {
+ pwf->nord = nBytesRead;
+ if (pwf->nelm > pwf->nord)
+ *((char *)pwf->bptr + pwf->nord) = '\0';
static long initWfWrite(waveformRecord *pwf)
Hi Andrew,
I will change asynPortDriver so that the setStringParam() method adds a Nil and passes that length to device support on readOctet or asynOctet callbacks. That will fix the problem with areaDetector, which is probably the main driver class using long strings
for path names, etc.
This cannot be moved up to asynWfOctetRead/asynWfOctetWrite device support in asyn/devEpics/devAsynOctet.c, because the asynOctet support for the waveform record needs to be able to handle binary data. However, we could add a new device support in there that
was specifically for strings, e.g. asynWfOctetStringRead/asynWfOctetStringWrite. These could enforce the Nils in both directions.
- Re: strange EPICS glitch Eric Norum
Re: procServ softIOC server - V2.6.0 released Ralph Lange
<2012>
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
