I'm trying to read a 32-bit hex value like ffffffff ffffffff using
EPICS R3.14.12.2, streamDevice 2-5, and asyn 4-19 on 64-bit Linux OS.
When I read these values using the following protocol:
get_ilock {
out "din";
in "%(\$1FirstInterlockWord.VAL)8R ",
"%(\$1SecondInterlockWord.VAL)0R";
ExtraInput = Ignore;
Both records are longin records and no matter if I use the 8R or 0R I
always get the same result:
ID06ds:FirstInterlockWord 11/12/12 14:03:02.743812335 -2147483648
ID06ds:SecondInterlockWord 11/12/12 14:03:02.743823268 -2147483648
Turns out that this is hex value 80000000
If I use a strngin record I can see that I'm getting the expected data.
Is this the largest value that I can read using streamDevice or is there
some other way that I should try to read these values?
Marty
- RE: streamDevice 32-bit hex value read problem Allison, Stephanie
- Re: streamDevice 32-bit hex value read problem Dirk Zimoch
RE: procServ softIOC server - V2.6.0 released Mark Rivers
Re: strange EPICS glitch Eric Norum
<2012>
Senior Software Engineer needed at MSU's FRIB careers
<2012>
