Thanks, Andrew and Benjamin!
I ended up deciding to make the generated doc part of the sources.
Which is bad, I know, but IMHO not as bad as forcing people to have root
access and install a fat toolchain (Doxygen/LaTeX), just because they
want to look at the manual.
The regular build just installs the existing stuff, while the new make
target "doxy" creates a new version of the documentation from the source
files.
To do that I added in .../Makefile:
INSTALL_DOCS += $(INSTALL_HTML)/MCoreUtils
DOCS += MCoreUtils.pdf
$(INSTALL_DOC)/%: ../documentation/%
$(ECHO) "Installing doc $@"
@$(INSTALL) -d -m $(INSTALL_PERMISSIONS) $< $(INSTALL_DOC)
$(INSTALL_HTML)/%: ../documentation/%
$(ECHO) "Installing html tree $@"
@$(MKDIR) -p $(INSTALL_HTML)
@$(CP) -rT $< $@
@find $@ -type f -exec chmod $(INSTALL_PERMISSIONS) {} \;
doxy:
@$(RMDIR) O.Common/doxy
@$(RMDIR) documentation
@$(MKDIR) -p documentation/MCoreUtils
@doxygen
@make -C O.Common/doxy/latex
@$(CP) O.Common/doxy/latex/refman.pdf documentation/MCoreUtils.pdf
@$(CP) -rT O.Common/doxy/html documentation/MCoreUtils
Thanks again,
~Ralph
- Doxygen and EPICS build system Ralph Lange
- Re: Doxygen and EPICS build system Benjamin Franksen
Re: Compilation error EPICS for RTEMS Bruno Seiva Martins
<2012>
CAC problem between RTEMS and vxWorks Wesley Moore
<2012>
