AFAIK the RTEMS-4.11 stuff is still a development branch.
I just checked and found that I could use EPICS/RTEMS-4.10 on my OS X "Mountain Lion" host as follows:
1) Download and install gmp-5.0.5, mpc-1.0., mpfr-3.1.1, automake-1.11.1and autoconf-2.68 with PREFX=/usr/llocal/rtems/rtems-4.10.
2) Run the getAndBuildTools-4.10.sh script (attached).
4) Ran the bootstrap script in the top RTEMS source directory.
5) Build RTEMS: /usr/local/rtems/rtems-4.10/src/rtems-4.10.2/configure --prefix=/usr/local/rtems/rtems-4.10 --enable-cxx --disable-rdbg --enable-tests=samples --enable-networking --enable-posix --target=powerpc-rtems4.10 '--enable-rtemsbsp=mvme3100 mvme2100 beatnik'
6) Build the RTEMS add-on packages (to get readline)
7) Build 'extended BSP' support.
8) Build EPICS with the attached configure/os/CONFIG_SITE.Common.RTEMS
I tried the above with the RTEMS-4.11 stuff but ran into problems at step (7) -- I couldn't get the the 'libbspExt' stuff to build. I don't think that there's anything wrong with the source, just the Makefile arrangements seem to have changed between 4.10 and 4.11. It would be nice if the bspExt stuff could migrate to RTEMS itself….
Description: Binary data
Please ignore the last message, it does not work...
- Re: Compilation error EPICS for RTEMS Joel Sherrill
- Compilation error EPICS for RTEMS Bruno Seiva Martins
- Re: Compilation error EPICS for RTEMS Bruno Seiva Martins
Re: camonitor bug for string as array of chars Ralph Lange
Re: ISEG EHS device support on the Raspberry Pi Computer Eric Norum
<2012>
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
