Mark,
I have a backwards compatible version of Eric's change attached.
Ron
On 9/6/2012 11:32 AM, Eric Norum wrote:
Yep, events are now strings.
Here's the quick fix that I made to work around this problem.
diff -ur
/usr/local/epics/R3.14.12/modules/soft/synApps_5_6/support/asyn4-20/asyn/devGpib/devCommonGpib.c
/usr/local/epics/R3.15.0/modules/src/asyn/trunk/asyn/devGpib/devCommonGpib.c
/usr/local/epics/R3.14.12/modules/soft/synApps_5_6/support/asyn4-20/asyn/devGpib/devCommonGpib.c 2008-07-24
13:39:29.000000000 -0700
/usr/local/epics/R3.15.0/modules/src/asyn/trunk/asyn/devGpib/devCommonGpib.2012-08-02
13:25:45.000000000 -0700
@@ -470,9 +470,7 @@
"%s no msg buffer\n",pev->name);
failure = -1;
} else {/* interpret msg with predefined format and
write into val/rval */
- char *format = (pgpibCmd->format) ?
(pgpibCmd->format) : "hu";
- if (sscanf(pgpibDpvt->msg, format,
&value) == 1) {
- pev->val = value;
+ if (sscanf(pgpibDpvt->msg, " %39s",
pev->val) == 1) {
pev->udf = FALSE;
} else { /* sscanf did not find or assign the
parameter */
failure = -1;
Mark,
Compiling either asyn-4.19 or
4-20 with EPICS R3.15.0.1 on Scientific Linux 6.1
gets the following error:
../../asyn/devGpib/devCommonGpib.c:
In function ‘evFinish’:
../../asyn/devGpib/devCommonGpib.c:475:
error: incompatible types when assigning to type
‘char[40]’ from type ‘short unsigned int’
make[2]: *** [devCommonGpib.o]
Error 1
make[2]: Leaving directory
‘/home/test/linux/prod/R3.15.0.1/asyn/asyn4-19/asyn/O.linux-x86’
The linux version is: Linux
version 2.6.32-131.0.15.el6.i686 ([email protected])
(gcc version 4.4.5 20110214 (Red Hat 4.4.5-6)
(GCC) ).
Is there a fix for this
please?
Jim
/* devCommonGpib.c */
* Copyright (c) 2002 The University of Chicago, as Operator of Argonne
* National Laboratory, and the Regents of the University of
* California, as Operator of Los Alamos National Laboratory, and
* Berliner Elektronenspeicherring-Gesellschaft m.b.H. (BESSY).
* asynDriver is distributed subject to a Software License Agreement
* found in file LICENSE that is included with this distribution.
* Current Author: Marty Kraimer
* Original Authors: John Winans and Benjamin Franksen
#include <stddef.h>
#include <string.h>
#include <stdlib.h>
#include <stddef.h>
#include <stdio.h>
#include <epicsAssert.h>
#include <epicsStdio.h>
#include <epicsVersion.h>
#include <recGbl.h>
#include <dbAccess.h>
#include <dbScan.h>
#include <alarm.h>
#include <devSup.h>
#include <recSup.h>
#include <callback.h>
#include <drvSup.h>
#include <link.h>
#include <errlog.h>
#include <menuFtype.h>
#include <shareLib.h>
#define epicsExportSharedSymbols
#include "asynDriver.h"
#include "asynGpibDriver.h"
#include "devSupportGpib.h"
#include "devCommonGpib.h"
/* The following is a generic finish routine for output records */
static void genericFinish(gpibDpvt * pgpibDpvt,int failure)
pdevSupportGpib->completeProcess(pgpibDpvt);
static void aiFinish(gpibDpvt *pgpibDpvt,int failure);
long devGpib_initAi(aiRecord * pai)
long result;
int cmdType;
gpibDpvt *pgpibDpvt;
DEVSUPFUN got_special_linconv = ((gDset *) pai->dset)->funPtr[5];
result = pdevSupportGpib->initRecord((dbCommon *) pai, &pai->inp);
if(result) return result;
pgpibDpvt = gpibDpvtGet(pai);
cmdType = gpibCmdGetType(pgpibDpvt);
if(!(cmdType&(GPIBREAD|GPIBREADW|GPIBRAWREAD|GPIBSOFT|GPIBCVTIO))) {
asynPrint(pgpibDpvt->pasynUser,ASYN_TRACE_ERROR,
"%s invalid command type for AI record in param %d\n",
pai->name, pgpibDpvt->parm);
pai->pact = TRUE;
return S_db_badField;
if(got_special_linconv) (*got_special_linconv)(pai,TRUE);
return 0;
long devGpib_readAi(aiRecord * pai)
gpibDpvt *pgpibDpvt = gpibDpvtGet(pai);
int cmdType;
if(pai->pact) return (got_special_linconv ? 0 : 2);
if(cmdType&GPIBSOFT) {
pdevSupportGpib->processGPIBSOFT(pgpibDpvt);
} else {
pdevSupportGpib->queueReadRequest(pgpibDpvt,0,aiFinish);
static void aiFinish(gpibDpvt * pgpibDpvt,int failure)
double value;
long rawvalue;
aiRecord *pai = ((aiRecord *) (pgpibDpvt->precord));
gpibCmd *pgpibCmd = gpibCmdGet(pgpibDpvt);
int cnvrtStat;
asynUser *pasynUser = pgpibDpvt->pasynUser;
if(failure) {; /*do nothing*/
} else if (pgpibCmd->convert) {
pasynUser->errorMessage[0] = 0;
cnvrtStat = pgpibCmd->convert(pgpibDpvt,
pgpibCmd->P1,pgpibCmd->P2,pgpibCmd->P3);
if(cnvrtStat==-1) {
asynPrint(pasynUser,ASYN_TRACE_ERROR,"%s convert failed %s\n",
pai->name,pasynUser->errorMessage);
failure = -1;
} else if (!pgpibDpvt->msg) {
asynPrint(pasynUser,ASYN_TRACE_ERROR, "%s no msg buffer\n",pai->name);
failure = -1;
} else {/* interpret msg with predefined format and write into val/rval */
int result = 0;
if(got_special_linconv) {
char *format = (pgpibCmd->format) ? (pgpibCmd->format) : "%ld";
result = sscanf(pgpibDpvt->msg, format, &rawvalue);
if(result==1) {pai->rval = rawvalue; pai->udf = FALSE;}
} else {
char *format = (pgpibCmd->format) ? (pgpibCmd->format) : "%lf";
result = sscanf(pgpibDpvt->msg, format, &value);
if(result==1) {pai->val = value; pai->udf = FALSE;}
if(result!=1) failure = -1;
if(failure==-1) recGblSetSevr(pai, READ_ALARM, INVALID_ALARM);
static int aoStart(gpibDpvt *pgpibDpvt,int failure);
long devGpib_initAo(aoRecord * pao)
long result;
int cmdType;
DEVSUPFUN got_special_linconv = ((gDset *) pao->dset)->funPtr[5];
/* do common initialization */
result = pdevSupportGpib->initRecord((dbCommon *) pao, &pao->out);
/* make sure the command type makes sense for the record type */
pgpibDpvt = gpibDpvtGet(pao);
if(!(cmdType&(GPIBWRITE|GPIBCMD|GPIBACMD|GPIBSOFT|GPIBCVTIO))) {
"%s invalid command type for AO record in param %d\n",
pao->name, pgpibDpvt->parm);
pao->pact = TRUE;
if(got_special_linconv) (*got_special_linconv)(pao,TRUE);
long devGpib_writeAo(aoRecord * pao)
gpibDpvt *pgpibDpvt = gpibDpvtGet(pao);
int cmdType = gpibCmdGetType(pgpibDpvt);
if(pao->pact) return 0;
} else {
pdevSupportGpib->queueWriteRequest(pgpibDpvt,aoStart,genericFinish);
return 0;
aoRecord *pao = ((aoRecord *) (pgpibDpvt->precord));
if(!failure && !pgpibCmd->convert) {
if (pgpibCmd->type&GPIBWRITE) {/* only if needs formatting */
if (got_special_linconv) {
failure = pdevSupportGpib->writeMsgLong(pgpibDpvt,pao->rval);
} else {
failure = pdevSupportGpib->writeMsgDouble(pgpibDpvt,pao->oval);
return failure;
static void biFinish(gpibDpvt *pgpibDpvt,int failure);
long devGpib_initBi(biRecord * pbi)
long result;
int cmdType;
devGpibNames *pdevGpibNames;
result = pdevSupportGpib->initRecord((dbCommon *) pbi, &pbi->inp);
pgpibDpvt = gpibDpvtGet(pbi);
if(!(cmdType&(GPIBREAD|GPIBREADW|GPIBRAWREAD|GPIBSOFT|GPIBCVTIO|GPIBEFASTI|GPIBEFASTIW))) {
"%s invalid command type for BI record in param %d\n",
pbi->name, pgpibDpvt->parm);
pbi->pact = TRUE;
pdevGpibNames = devGpibNamesGet(pgpibDpvt);
if(pdevGpibNames) {
if (pbi->znam[0] == 0) strcpy(pbi->znam, pdevGpibNames->item[0]);
if (pbi->onam[0] == 0) strcpy(pbi->onam, pdevGpibNames->item[1]);
return 0;
long devGpib_readBi(biRecord * pbi)
gpibDpvt *pgpibDpvt = gpibDpvtGet(pbi);
int cmdType;
if(pbi->pact) return 0;
} else {
pdevSupportGpib->queueReadRequest(pgpibDpvt,0,biFinish);
return 0;
static void biFinish(gpibDpvt * pgpibDpvt,int failure)
biRecord *pbi = ((biRecord *) (pgpibDpvt->precord));
unsigned long value;
int cnvrtStat;
if(cnvrtStat==-1) {
pbi->name,pasynUser->errorMessage);
failure = -1;
} else if(pgpibCmd->type&(GPIBEFASTI|GPIBEFASTIW)) {
if(pgpibDpvt->efastVal>=0) {
pbi->rval = pgpibDpvt->efastVal;
} else {
failure = -1;
"%s no msg buffer\n",pbi->name);
failure = -1;
} else {
char *format = (pgpibCmd->format) ? (pgpibCmd->format) : "%lu";
if(sscanf(pgpibDpvt->msg, format, &value) == 1) {
pbi->rval = value;
} else {
/* sscanf did not find or assign the parameter*/
failure = -1;
asynPrint(pasynUser,ASYN_TRACE_ERROR,"%s can't convert msg >%s<\n",
pbi->name, pgpibDpvt->msg);
if(failure==-1) recGblSetSevr(pbi, READ_ALARM, INVALID_ALARM);
static int boStart(gpibDpvt *pgpibDpvt,int failure);
static void writeBoSpecial(boRecord * pbo);
static void boWorkSpecial(gpibDpvt *pgpibDpvt,int failure);
static char *ifcName[] = {"noop", "IFC", 0};
static char *renName[] = {"drop REN", "assert REN", 0};
static char *dclName[] = {"noop", "DCL", "0"};
static char *lloName[] = {"noop", "LLO", "0"};
static char *sdcName[] = {"noop", "SDC", "0"};
static char *gtlName[] = {"noop", "GTL", "0"};
long devGpib_initBo(boRecord * pbo)
long result;
int cmdType;
result = pdevSupportGpib->initRecord((dbCommon *) pbo, &pbo->out);
pgpibDpvt = gpibDpvtGet(pbo);
if(cmdType&(GPIBIFC|GPIBREN|GPIBDCL|GPIBLLO|GPIBSDC|GPIBGTL)) {
/* supply defaults for menus */
char **papname = 0;
switch (cmdType) {
case GPIBIFC: papname = ifcName; break;
case GPIBREN: papname = renName; break;
case GPIBDCL: papname = dclName; break;
case GPIBLLO: papname = lloName; break;
case GPIBSDC: papname = sdcName; break;
case GPIBGTL: papname = gtlName; break;
default:
"%s devGpib_initBo logic error\n",pbo->name);
if (papname) {
if (pbo->znam[0] == 0) strcpy(pbo->znam, papname[0]);
if (pbo->onam[0] == 0) strcpy(pbo->onam, papname[1]);
} else if(!(cmdType&(GPIBWRITE|GPIBCMD|GPIBACMD|GPIBEFASTO|GPIBSOFT|GPIBCVTIO))) {
"%s invalid command type for BO record in param %d\n",
pbo->name, pgpibDpvt->parm);
pbo->pact = TRUE;
if(pdevGpibNames) {
if (pbo->znam[0] == 0) strcpy(pbo->znam, pdevGpibNames->item[0]);
if (pbo->onam[0] == 0) strcpy(pbo->onam, pdevGpibNames->item[1]);
return 2;
long devGpib_writeBo(boRecord * pbo)
gpibDpvt *pgpibDpvt = gpibDpvtGet(pbo);
if(pbo->pact) return 0;
} else
writeBoSpecial(pbo);
} else {
pdevSupportGpib->queueWriteRequest(pgpibDpvt,boStart,genericFinish);
return 0;
static int boStart(gpibDpvt * pgpibDpvt,int failure)
boRecord *pbo = (boRecord *)pgpibDpvt->precord;
failure = pdevSupportGpib->writeMsgULong(pgpibDpvt,pbo->rval);
} else if (pgpibCmd->type&GPIBEFASTO) {
pgpibDpvt->efastVal = pbo->val;
return failure;
if(pbo->pact) return;
if(cmdType&(GPIBIFC|GPIBDCL|GPIBLLO|GPIBSDC|GPIBGTL)) {
if(pbo->val==0) return;
pdevSupportGpib->queueRequest(pgpibDpvt,boWorkSpecial);
return;
boRecord *precord = (boRecord *)pgpibDpvt->precord;
int val = (int)precord->val;
asynGpib *pasynGpib = pgpibDpvt->pasynGpib;
void *drvPvt = pgpibDpvt->asynGpibPvt;
asynStatus status = asynSuccess;
} else if(!pasynGpib) {
failure = -1;
"%s pasynGpib is 0\n",precord->name);
} else switch(cmdType) {
case GPIBIFC: status = pasynGpib->ifc(drvPvt,pasynUser); break;
case GPIBREN: status = pasynGpib->ren(drvPvt,pasynUser,val); break;
case GPIBDCL:
status = pasynGpib->universalCmd(drvPvt,pasynUser,IBDCL);
break;
case GPIBLLO:
status = pasynGpib->universalCmd(drvPvt,pasynUser,IBLLO);
break;
case GPIBSDC:
status = pasynGpib->addressedCmd(drvPvt,pasynUser,IBSDC,1);
break;
case GPIBGTL:
status = pasynGpib->addressedCmd(drvPvt,pasynUser,IBGTL,1);
break;
default: status = asynError; break;
if(status!=asynSuccess) failure = -1;
if(failure==-1) recGblSetSevr(precord, WRITE_ALARM, INVALID_ALARM);
static void evFinish(gpibDpvt *pgpibDpvt,int failure);
long devGpib_initEv(eventRecord * pev)
long result;
int cmdType;
result = pdevSupportGpib->initRecord((dbCommon *) pev, &pev->inp);
pgpibDpvt = gpibDpvtGet(pev);
"%s invalid command type for EV record in param %d\n",
pev->name, pgpibDpvt->parm);
pev->pact = TRUE;
return 0;
long devGpib_readEv(eventRecord * pev)
gpibDpvt *pgpibDpvt = gpibDpvtGet(pev);
int cmdType;
if(pev->pact) return 0;
} else {
pdevSupportGpib->queueReadRequest(pgpibDpvt,0,evFinish);
return 0;
static void evFinish(gpibDpvt * pgpibDpvt,int failure)
eventRecord *pev = ((eventRecord *) (pgpibDpvt->precord));
int cnvrtStat;
if(cnvrtStat==-1) {
pev->name,pasynUser->errorMessage);
failure = -1;
failure = -1;
#if ((EPICS_VERSION<=(3)) && (EPICS_REVISION<=(14)))
unsigned short value;
char *format = (pgpibCmd->format) ? (pgpibCmd->format) : "hu";
if (sscanf(pgpibDpvt->msg, format, &value) == 1) {
pev->val = value;
#else
if (sscanf(pgpibDpvt->msg, " %39s", pev->val) == 1) {
#endif
pev->udf = FALSE;
} else { /* sscanf did not find or assign the parameter */
failure = -1;
if(failure==-1) recGblSetSevr(pev, READ_ALARM, INVALID_ALARM);
static void liFinish(gpibDpvt *pgpibDpvt,int failure);
static void liSrqHandler(void *userPrivate,asynUser *pasynUser,
epicsInt32 statusByte)
longinRecord *pli = (longinRecord *)userPrivate;
gpibDpvt *pgpibDpvt = gpibDpvtGet(pli);
pli->val = statusByte;
pli->udf = FALSE;
scanOnce(pgpibDpvt->precord);
long devGpib_initLi(longinRecord * pli)
long result;
int cmdType;
result = pdevSupportGpib->initRecord((dbCommon *) pli, &pli->inp);
if(!(cmdType&(GPIBREAD|GPIBREADW|GPIBRAWREAD|GPIBSOFT|GPIBCVTIO|GPIBSRQHANDLER))) {
"%s invalid command type for LI record in param %d\n",
pli->name, pgpibDpvt->parm);
pli->pact = TRUE;
if(cmdType&GPIBSRQHANDLER) {
pdevSupportGpib->registerSrqHandler(pgpibDpvt,liSrqHandler,pli);
return 0;
long devGpib_readLi(longinRecord * pli)
int cmdType;
/*printf("READ -- %s %d %p\n", pli->name, pli->val, &pli->val);*/
if(pli->pact) return 0;
if(cmdType&GPIBSRQHANDLER) return 0;
} else {
pdevSupportGpib->queueReadRequest(pgpibDpvt,0,liFinish);
return 0;
static void liFinish(gpibDpvt * pgpibDpvt,int failure)
long value;
longinRecord *pli = ((longinRecord *) (pgpibDpvt->precord));
int cnvrtStat;
if(cnvrtStat==-1) {
pli->name,pasynUser->errorMessage);
failure = -1;
/*printf("HI THERE -- %s %d\n", pli->name, pli->val); */
/*printf("HI THERE -- %s %p\n", pli->name, &pli->val);*/
"%s no msg buffer\n",pli->name);
failure = -1;
pli->val = value; pli->udf = FALSE;
failure = -1;
if(failure==-1) recGblSetSevr(pli, READ_ALARM, INVALID_ALARM);
static int loStart(gpibDpvt *pgpibDpvt,int failure);
long devGpib_initLo(longoutRecord * plo)
long result;
int cmdType;
result = pdevSupportGpib->initRecord((dbCommon *) plo, &plo->out);
pgpibDpvt = gpibDpvtGet(plo);
"%s invalid command type for LO record in param %d\n",
plo->name, pgpibDpvt->parm);
plo->pact = TRUE;
return 0;
long devGpib_writeLo(longoutRecord * plo)
gpibDpvt *pgpibDpvt = gpibDpvtGet(plo);
if(plo->pact) return 0;
} else {
pdevSupportGpib->queueWriteRequest(pgpibDpvt,loStart,genericFinish);
return 0;
static int loStart(gpibDpvt * pgpibDpvt,int failure)
longoutRecord *plo = ((longoutRecord *) (pgpibDpvt->precord));
failure = pdevSupportGpib->writeMsgLong(pgpibDpvt, plo->val);
return failure;
static void mbbiFinish(gpibDpvt *pgpibDpvt,int failure);
long devGpib_initMbbi(mbbiRecord * pmbbi)
long result;
int cmdType;
int name_ct; /* for filling in the name strings */
char *name_ptr; /* index into name list array */
epicsUInt32 *val_ptr; /* indev into the value list array */
result = pdevSupportGpib->initRecord((dbCommon *) pmbbi, &pmbbi->inp);
pgpibDpvt = gpibDpvtGet(pmbbi);
"%s invalid command type for MBBI record in param %d\n",
pmbbi->name, pgpibDpvt->parm);
pmbbi->pact = TRUE;
if(pdevGpibNames) {
if (pdevGpibNames->value == NULL) {
"%s: init_rec_mbbi: MBBI value list wrong for param"
" #%d\n", pmbbi->name, pgpibDpvt->parm);
pmbbi->pact = TRUE;
pmbbi->nobt = pdevGpibNames->nobt;
name_ct = 0; /* current name string element */
name_ptr = pmbbi->zrst; /* first name string element */
val_ptr = &(pmbbi->zrvl); /* first value element */
while (name_ct < pdevGpibNames->count) {
if (name_ptr[0] == 0) {
strcpy(name_ptr, pdevGpibNames->item[name_ct]);
*val_ptr = pdevGpibNames->value[name_ct];
name_ct++;
name_ptr += sizeof(pmbbi->zrst);
val_ptr++;
return 0;
long devGpib_readMbbi(mbbiRecord * pmbbi)
gpibDpvt *pgpibDpvt = gpibDpvtGet(pmbbi);
int cmdType;
if(pmbbi->pact) return 0;
} else {
pdevSupportGpib->queueReadRequest(pgpibDpvt,0,mbbiFinish);
return 0;
static void mbbiFinish(gpibDpvt * pgpibDpvt,int failure)
mbbiRecord *pmbbi = ((mbbiRecord *) (pgpibDpvt->precord));
int cnvrtStat;
if(cnvrtStat==-1) {
pmbbi->name,pasynUser->errorMessage);
failure = -1;
pmbbi->rval = pgpibDpvt->efastVal;
} else {
failure = -1;
"%s no msg buffer\n",pmbbi->name);
failure = -1;
} else {
pmbbi->rval = value;
} else {
/*sscanf did not find or assign the parameter*/
failure = -1;
pmbbi->name, pgpibDpvt->msg);
if(failure==-1) recGblSetSevr(pmbbi, READ_ALARM, INVALID_ALARM);
static void mbbiDirectFinish(gpibDpvt *pgpibDpvt,int failure);
long devGpib_initMbbiDirect(mbbiDirectRecord * pmbbiDirect)
long result;
int cmdType;
(dbCommon *) pmbbiDirect, &pmbbiDirect->inp);
pgpibDpvt = gpibDpvtGet(pmbbiDirect);
"%s invalid command type for MBBI_DIRECT record in param %d\n",
pmbbiDirect->name, pgpibDpvt->parm);
pmbbiDirect->pact = TRUE;
return 0;
long devGpib_readMbbiDirect(mbbiDirectRecord * pmbbiDirect)
gpibDpvt *pgpibDpvt = gpibDpvtGet(pmbbiDirect);
int cmdType;
if(pmbbiDirect->pact) return 0;
} else {
pdevSupportGpib->queueReadRequest(pgpibDpvt,0,mbbiDirectFinish);
return 0;
static void mbbiDirectFinish(gpibDpvt * pgpibDpvt,int failure)
mbbiDirectRecord *pmbbiDirect = ((mbbiDirectRecord *) (pgpibDpvt->precord));
int cnvrtStat;
if(cnvrtStat==-1) {
pmbbiDirect->name,pasynUser->errorMessage);
failure = -1;
"%s no msg buffer\n",pmbbiDirect->name);
failure = -1;
} else {
pmbbiDirect->rval = value;
} else {
failure = -1;
pmbbiDirect->name, pgpibDpvt->msg);
if(failure==-1) recGblSetSevr(pmbbiDirect, READ_ALARM, INVALID_ALARM);
static int mbboStart(gpibDpvt *pgpibDpvt,int failure);
long devGpib_initMbbo(mbboRecord * pmbbo)
long result;
int cmdType;
result = pdevSupportGpib->initRecord((dbCommon *) pmbbo, &pmbbo->out);
pgpibDpvt = gpibDpvtGet(pmbbo);
"%s invalid command type for MBBO record in param %d\n",
pmbbo->name, pgpibDpvt->parm);
pmbbo->pact = TRUE;
if (pdevGpibNames) {
"%s: init_rec_mbbo: MBBO value list wrong for param"
" #%d\n", pmbbo->name, pgpibDpvt->parm);
pmbbo->pact = TRUE;
pmbbo->nobt = pdevGpibNames->nobt;
name_ptr = pmbbo->zrst; /* first name string element */
val_ptr = &(pmbbo->zrvl); /* first value element */
name_ct++;
name_ptr += sizeof(pmbbo->zrst);
val_ptr++;
return 2;
long devGpib_writeMbbo(mbboRecord * pmbbo)
gpibDpvt *pgpibDpvt = gpibDpvtGet(pmbbo);
if(pmbbo->pact) return 0;
} else {
pdevSupportGpib->queueWriteRequest(pgpibDpvt,mbboStart,genericFinish);
return 0;
static int mbboStart(gpibDpvt * pgpibDpvt,int failure)
mbboRecord *pmbbo = (mbboRecord *)pgpibDpvt->precord;
failure = pdevSupportGpib->writeMsgULong(pgpibDpvt,pmbbo->rval);
pgpibDpvt->efastVal = pmbbo->val;
return failure;
static int mbboDirectStart(gpibDpvt *pgpibDpvt,int failure);
long devGpib_initMbboDirect(mbboDirectRecord * pmbboDirect)
long result;
int cmdType;
result = pdevSupportGpib->initRecord((dbCommon *)pmbboDirect,&pmbboDirect->out);
pgpibDpvt = gpibDpvtGet(pmbboDirect);
"%s invalid command type for MBBO_DIRECT record in param %d\n",
pmbboDirect->name, pgpibDpvt->parm);
pmbboDirect->pact = TRUE;
return 2;
long devGpib_writeMbboDirect(mbboDirectRecord * pmbboDirect)
gpibDpvt *pgpibDpvt = gpibDpvtGet(pmbboDirect);
if(pmbboDirect->pact) return 0;
} else {
mbboDirectStart,genericFinish);
return 0;
static int mbboDirectStart(gpibDpvt * pgpibDpvt,int failure)
mbboDirectRecord *pmbboDirect = ((mbboDirectRecord *) (pgpibDpvt->precord));
failure = pdevSupportGpib->writeMsgULong(pgpibDpvt,pmbboDirect->rval);
return failure;
static void siFinish(gpibDpvt *pgpibDpvt,int failure);
long devGpib_initSi(stringinRecord * psi)
long result;
int cmdType;
result = pdevSupportGpib->initRecord((dbCommon *) psi, &psi->inp);
if(result) return (result);
pgpibDpvt = gpibDpvtGet(psi);
"%s invalid command type for SI record in param %d\n",
psi->name, pgpibDpvt->parm);
psi->pact = TRUE;
return 0;
long devGpib_readSi(stringinRecord * psi)
gpibDpvt *pgpibDpvt = gpibDpvtGet(psi);
int cmdType;
if(psi->pact) return 0;
} else {
pdevSupportGpib->queueReadRequest(pgpibDpvt,0,siFinish);
return 0;
static void siFinish(gpibDpvt * pgpibDpvt,int failure)
stringinRecord *psi = ((stringinRecord *) (pgpibDpvt->precord));
int cnvrtStat;
if(cnvrtStat==-1) {
psi->name,pasynUser->errorMessage);
failure = -1;
"%s no msg buffer\n",psi->name);
failure = -1;
} else {
char *format = (pgpibCmd->format) ? pgpibCmd->format : "%39c";
if(sscanf(pgpibDpvt->msg, format, psi->val) != 1) {
failure = -1;
psi->name, pgpibDpvt->msg);
psi->udf = FALSE;
if(failure==-1) recGblSetSevr(psi, READ_ALARM, INVALID_ALARM);
static int soStart(gpibDpvt *pgpibDpvt,int failure);
long devGpib_initSo(stringoutRecord * pso)
long result;
int cmdType;
result = pdevSupportGpib->initRecord((dbCommon *) pso, &pso->out);
pgpibDpvt = gpibDpvtGet(pso);
"%s invalid command type for SO record in param %d\n",
pso->name, pgpibDpvt->parm);
pso->pact = TRUE;
return 0;
long devGpib_writeSo(stringoutRecord * pso)
gpibDpvt *pgpibDpvt = gpibDpvtGet(pso);
if(pso->pact) return 0;
} else {
pdevSupportGpib->queueWriteRequest(pgpibDpvt,soStart,genericFinish);
return 0;
stringoutRecord *pso = ((stringoutRecord *) (pgpibDpvt->precord));
failure = pdevSupportGpib->writeMsgString(pgpibDpvt, pso->val);
return failure;
static int wfStart(gpibDpvt *pgpibDpvt,int failure);
static void wfFinish(gpibDpvt *pgpibDpvt,int failure);
long devGpib_initWf(waveformRecord * pwf)
long result;
int cmdType;
gpibCmd *pgpibCmd;
result = pdevSupportGpib->initRecord((dbCommon *) pwf, &pwf->inp);
pgpibDpvt = gpibDpvtGet(pwf);
if(cmdType&(GPIBREAD|GPIBREADW|GPIBRAWREAD)) {
if((!pgpibCmd->convert) && (pwf->ftvl!=menuFtypeCHAR)) {
"%s ftvl != CHAR but no convert\n", pwf->name);
pwf->pact = 1;
} else if(!(cmdType&(GPIBSOFT|GPIBCVTIO|GPIBWRITE|GPIBCMD|GPIBACMD))) {
"%s invalid command type for WF record in param %d\n",
pwf->name, pgpibDpvt->parm);
pwf->pact = TRUE;
return 0;
long devGpib_readWf(waveformRecord * pwf)
gpibDpvt *pgpibDpvt = gpibDpvtGet(pwf);
if(pwf->pact) return 0;
return 0;
pdevSupportGpib->queueReadRequest(pgpibDpvt,0,wfFinish);
} else { /*Must be Output Operation*/
pdevSupportGpib->queueWriteRequest(pgpibDpvt,wfStart,wfFinish);
return 0;
static int wfStart(gpibDpvt * pgpibDpvt,int failure)
waveformRecord *pwf = (waveformRecord *)pgpibDpvt->precord;
if(!failure && !pgpibCmd->convert && (pgpibCmd->type&GPIBWRITE)) {
if(pwf->ftvl!=menuFtypeCHAR) {
pwf->pact = 1;
failure = -1;
} else {
failure = pdevSupportGpib->writeMsgString(pgpibDpvt, pwf->bptr);
return failure;
static void wfFinish(gpibDpvt * pgpibDpvt,int failure)
int cnvrtStat;
} else if(cmdType&(GPIBREAD|GPIBREADW|GPIBRAWREAD)) {
if(pgpibCmd->convert) {
if(cnvrtStat==-1) {
pwf->name,pasynUser->errorMessage);
failure = -1;
} else if(pwf->ftvl!=menuFtypeCHAR) {
"%s ftvl != CHAR but no convert\n",pwf->name);
failure = -1;
} else {
char *format = (pgpibCmd->format) ? pgpibCmd->format : "%s";
int lenDest = pwf->nelm;
char *pdest = (char *)pwf->bptr;
int nchars;
nchars = epicsSnprintf(pdest,lenDest,format,pgpibDpvt->msg);
if(nchars>=lenDest) {
pdest[lenDest-1] = 0;
"%s %d characters were truncated\n",
pwf->name,(nchars-lenDest+1));
failure = -1;
nchars = lenDest;
pwf->udf = FALSE;
pwf->nord = nchars;
if(failure==-1) recGblSetSevr(pwf, READ_ALARM, INVALID_ALARM);
- asyn4-20 compiling error on Scientific Linux 6.1 Jim Chen
- Re: asyn4-20 compiling error on Scientific Linux 6.1 Eric Norum
RE: asyn4-20 compiling error on Scientific Linux 6.1 Jim Chen
RE: Epics driver using BLT or CBLT to read FIFO wanted Mark Rivers
<2012>
mca R7-2 available Mark Rivers
<2012>
