1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: asyn R4-20 available
Cc: "'Beamline Controls and Data Acquisition'" <[email protected]>
Date: Fri, 31 Aug 2012 18:28:38 +0000
Folks,
asyn R4-20 is now available.  Links to the new documentation, release notes and tar file can be found here:
http://www.aps.anl.gov/epics/modules/soft/asyn/
asyn is also available via the APS Subversion repository here:
https://svn.aps.anl.gov/epics/asyn/
This is from the release notes:
- asynManager
Fixed a bug that caused a deadlock if pasynManager->lockPort was called multiple times without calling pasynManager->unlockPort in between. Thanks to Sebastian Marsching from "aquenos GmbH" for this fix.
- devEpics
Added support for setting the record timestamp from the driver, using a new field, pasynUser->timeStamp. The driver can set this field in read and callback operations.
Fixed a long-standing bug in devAsynXXXArray support for input waveform records with SCAN=I/O Intr. The data were being copied to the record without using dbScanLock. This meant that the data could change while the record was processing.
Changed the "ring buffer overflow" messages from "ASYN_TRACE_ERROR" to "ASYN_TRACEIO_DEVICE", so they do not appear by default. These messages are not really errors, but warnings that record processing it not keeping up with the rate of driver callbacks for records with SCAN=I/O Intr.
Prev: RE: modbus R2-4 write 32bit int with modbus function 16 Mark Rivers
Next: RE: put to disabled records and monitors Pal Trivan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: edm and other extensions on 64-bit SL machines Pierrick Hanlet
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
