Andrew Johnson wrote:
Announcing the first developer release in the Base 3.15 series, version
3.15.0.1 is now available for download and testing. Many new features have
been incorporated into the code that have been in development since 2008 and
were contributed by users from many different sites. Some of the changes have
not even been mentioned in the Release Notes yet, but many have. Please read
the release notes to get some idea what's new. Some updates were covered in
the Application Developers Guide instead (or even as well), although the
changes in that document might be a bit hard to spot.
Documentation and downloads available at
http://www.aps.anl.gov/epics/base/R3-15/0.php
Thanks to everyone who has worked on this over the last few years (and please
consider writing some documentation for your contribution, it's not much use
it nobody knows how to use it!).
Note: This release should not be used for operational systems, it could blow
holes in your beam pipe (or insert empty beer-cans into them), quench your
superconducting magnets, or adjust all your undulator gaps to zero. Actually
we don't guarantee that our regular releases won't do those things by mistake
either, but this release contains new code that has not been significantly
tested.
- Andrew
Older Linux versions still require ncurses in addition to readline,
otherwise linking fails with undefined references.
Is there a way to automatically find out which Linux/Unix version
requires curses or ncurses in addition to readline?
Is it possible to prompt the innocent user with a helpful error message like
Edit COMMANDLINE_LIBRARY variable in configure/CONFIG_SITE.Common.$(T_A)
instead of
/usr/lib/libreadline.so.5: undefined reference to `PC'
/usr/lib/libreadline.so.5: undefined reference to `tgetflag'
/usr/lib/libreadline.so.5: undefined reference to `tgetent'
/usr/lib/libreadline.so.5: undefined reference to `UP'
/usr/lib/libreadline.so.5: undefined reference to `tputs'
/usr/lib/libreadline.so.5: undefined reference to `tgoto'
/usr/lib/libreadline.so.5: undefined reference to `tgetnum'
/usr/lib/libreadline.so.5: undefined reference to `BC'
when linking iocLogServer?
BTW: Why does iocLogServer need readline? Maybe some library
dependencies need to be cleaned up.
Dirk
- EPICS Base version 3.15.0.1 released Andrew Johnson
Re: EPICS Base version 3.15.0.1 released Martin Konrad
Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
<2012>
Re: EPICS Base version 3.15.0.1 released Andrew Johnson
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
