Hey guys,
Thanks for all your help and advice. Using gdb I found my problem was not assigning the appropriate amount of memory to copy the record msg char* into a buffer char*. I fixed this by just accessing the record msg directly without copying it. Attached below is the custom conversion routine I found works well and reliably.
// WF read routine for AGE5071C, converts Hz to MHz for P1==1
static int readWF(struct gpibDpvt *pdpvt,int P1, int P2, char**P3) {
struct waveformRecord *pwf=(struct waveformRecord *)pdpvt->precord;
asynUser *pasynUser = pdpvt->pasynUser;
double* value = (double *)pwf->bptr;
double data;
int n;
pwf->nord=0;
while ((pwf->nord < pwf->nelm) && sscanf(pdpvt->msg,"%lE,%n",&data,&n)==1) {
if (P1==1) data/=1E6;
memcpy(value+pwf->nord,&data,sizeof(double));
pwf->nord++;
pdpvt->msg+=n;
asynPrint(pasynUser,ASYN_TRACE_FLOW,"(NORD,VAL) : (%i,%E)\n",pwf->nord,data);
if (pwf->nord == 0) return -1;
pwf->udf = 0;
return 0;
I can definitely see now the the advantages of using stream device. I my system control needs become more complicated I'll switch over to using that instead of asynGpib.
Cheers,
Andrew
On Mon, 30 Jul 2012, Eric Norum wrote:
I put together a simple StreamDevice/ASYN application and a small python script to provide a dummy 'instrument'. The instrument provides 30000 values on demand.
Things seem to work as expected. Here's the output from the final command of the startup script:
dbpr "wchk:1:Wave"
ASG: BUSY: 0 DESC: Read a long waveform
DISA: 0 DISP: 0 DISV: 1 NAME: wchk:1:Wave
NORD: 30000 SEVR: NO_ALARM STAT: NO_ALARM TPRO: 0
VAL: 0x0
As you can see, the IOC has successfully read 30000 double values from the instrument.
Andrew -- perhaps you can massage the attached application a little to match the commands of your hardware and see if things work for you as well?
- Re: Waveform read problems Eric Norum
<2012>
<2012>
