g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Consequences of the leap-second
To: "EPICS tech-talk" <tech-talk@aps.anl.gov>
Date: Mon, 2 Jul 2012 11:48:32 -0500
In case your site has this issue but maybe hasn't noticed yet:  There was a
leap-second over the weekend, and it had all sorts of interesting consequences
to Linux systems around the interwebs:
http://www.pcmag.com/article2/0,2817,2406583,00.asp
http://www.computerworld.com/s/article/9228720/Leap_second_bedevils_Web_systems_over_weekend?taxonomyId=122
It seems that all the RHEL6 systems at APS that were running any kind of a JVM
have been pegging a CPU, and even Firefox is eating up 100% of a CPU on my box
despite restarting the program.  An OS reboot apparently fixes the problem,
but if you have any kind of OS support contract you might want to check with
them first since they might have a less drastic fix available.
Time on some of our vxWorks IOCs (those that get their time from our Master
Timing IOC either through the event system or from the time broadcasts) is
currently running 1 second ahead of NTP time.  I suspect that this will not
correct itself until we reboot the Master Timing IOC, and then we'll need to
be prepared for worse things to happen:
iocrfcavs37> generalTimeReport 2
Backwards time errors prevented 821232 times.
Current Time Providers:
    "APS Event Receiver", priority = 70
        Current Time is 2012-07-02 11:34:02.450920.
    "APS Time Broadcast", priority = 75
        Current Time is 2012-07-02 11:34:02.458920.
    "NTP", priority = 100
        Current Time is 2012-07-02 11:34:01.446454.
    "OS Clock", priority = 999
        Current Time is 2012-07-02 11:34:02.449253.
Event Time Providers:
value = 0 = 0x0
iocvidcentral> generalTimeReport 2
Backwards time errors prevented 2574916 times.
        Current Time is 2012-07-02 11:39:31.579253.
        Current Time is 2012-07-02 11:39:30.567739.
        Current Time is 2012-07-02 11:39:31.580253.
        No Providers registered.
value = 0 = 0x0
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: Consequences of the leap-second Sean Murray
RE: Consequences of the leap-second michael.abbott
Prev: Re: Consequences of the leap-second Sean Murray
Next: Re: iptables example script for EPICS CA Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: scan save data problem Chen Xue
Next: Re: Consequences of the leap-second Sean Murray
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
