Eric Norum wrote:
On Jun 5, 2012, at 9:46 AM, Andrew Johnson wrote:
Hi Eric,
On Jun 5, 2012, at 6:11 AM, Dirk Zimoch wrote:
I think adding something like this to epicsStrtod should fix the problem:
if (epicsStrnCaseCmp("0x", cp, 2) == 0) {
return (double)strtoul(str, endp, 16);
I'll be using strtol() instead in the 3.15 code, so -0x1 works.
Right.
I had assumed that the primary application for hex numbers would be bit
masks. Signed masks do not make much sense but 0x80000000 does make
sense. Maybe we should test for minus and then either call strtol() or
strtoul().
On 2012-06-05 Eric Norum wrote:
The code with that change doesn't completely match the semantics of strtod
as presented in the C99 standard, but it's certainly better than the
current code.
What else are we missing? I don't have the C99 standard to look at here.
A '0x' number can have a fractional part and an exponent. This seems pretty esoteric so its absence is, IMHO, minor.
Nobody right in his mind uses hexadecimal floating point numbers. ;-)
BTW -- does vxWorks still not supply a working strtod? I
think that it is the only system that doesn't just define epicsStrtod as
strtod.
The wording in the vxWorks 6.8 manpage is exactly the same as Dirk posted from
vxWorks 5.5.
My argument is: Yes, vxWorks 5.5 still does not supply a working strtod.
Changing the vxWorks version is not as simple as upgrading Ubuntu.
No, we use our version of epicsStrtod() on Windows, Cygwin, vxWorks and
Solaris. I have a branch for 3.15 where I've been working on the numeric
conversions, I'll add some tests for the native strtod().
Yuck.
After over 12 years they still can't produce a strtod that matches the standard? (!!!)
They are WindRiver (or rather Intel now). They make their own standard.
- Re: mask for bitwise operation in CALC record Andrew Johnson
- mask for bitwise operation in CALC record haquin
- Re: mask for bitwise operation in CALC record Dirk Zimoch
- Re: mask for bitwise operation in CALC record Eric Norum
Re: Announcement of PCaPAC-2012 Shantonu Sahoo
[CSS] text edit + Go! button Pavel Masloff
<2012>
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
