g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: [Scopes] BMP image record??
To: EPICS Tech Talk <tech-talk@aps.anl.gov>
Date: Sat, 28 Apr 2012 11:17:19 +0400
Hello again,
As I mentioned earlier we are running a series of experiments with our high current switches. I have written simple support ("...with a little help from my friend" Dirk Zimoch) for the Tektronix TPS2000 over RS232 using StreamDevice and ASYN, so now I can remotely arm the scopes, set its properties, save waveforms on to the CF card, etc. But...
In order to not run back and forth and see if everything went OK (which is rather tiresome and time consuming), we need a confirmation from the scopes. I don't want to deal with the implementation of the waveform records for now, all I have got so far is that I save them on the flash card.
As such a confirmation I see transferring the BMP (or PNG) image from the scope (sort of Print screen) on to the operator PC somehow.
There is a special SCPI command "Hardcopy start". Which mimics the Print button on the scope's front panel. I have tried to transfer a BMP file via Hyperterminal (and Python script) and it worked out well (more or less).
How could this be ported to the EPICS database from the IOC and client standpoint, so an operator could see the oscillogram on the screen and decide whether the experiment went well, so she will save the waveforms and move on to the next experiment?
The image file is maximum ~ 46Kb (20Kb on average).
Any thoughts?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
RE: [Scopes] BMP image record?? Mark Rivers
Re: [Scopes] BMP image record?? Dirk Zimoch
Prev: Re: [StreamDevice] need advice Pavel Masloff
Next: [ASYN] connect/disconnect Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: Re: ECHO variable in build rules Andrew Johnson
Next: RE: [Scopes] BMP image record?? Mark Rivers
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
