Hi folks,
Banging my head against a Windows build error...
I'm trying to get to the stage where I can build AreaDetector 1-7 on 64-bit Windows 7. I can successfully build base-13-12-1 and asyn-4-18, but my first hurdle is that busy 1-4 fails with the following link error:
Creating library busy.lib and object busy.exp
devBusyAsyn.obj : error LNK2001: unresolved external symbol pasynEpicsUtils
devBusyAsyn.obj : error LNK2001: unresolved external symbol pasynInt32SyncIO
devBusyAsyn.obj : error LNK2001: unresolved external symbol pasynManager
devBusyAsyn.obj : error LNK2001: unresolved external symbol pasynTrace
busy.dll : fatal error LNK1120: 4 unresolved externals
make[3]: *** [busy.dll] Error 1120
make[3]: Leaving directory `C:/beamline/perforce/Dev/SBS/4_Controls/4_3_Network_Infrastructure/4_3_1_Comms_Common_Services/sw/epics/busy-1-4/busyApp/src/O.windows-x64'
make[2]: *** [install.windows-x64] Error 2
make[2]: Leaving directory `C:/beamline/perforce/Dev/SBS/4_Controls/4_3_Network_Infrastructure/4_3_1_Comms_Common_Services/sw/epics/busy-1-4/busyApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `C:/beamline/perforce/Dev/SBS/4_Controls/4_3_Network_Infrastructure/4_3_1_Comms_Common_Services/sw/epics/busy-1-4/busyApp'
make: *** [busyApp.install] Error 2
I'm using Visual Studio 2010, and gnumake. The problem seems to be with the version of EPICS base, as I get the same problem when I try to compile it as 32-bit as well unless I revert to EPICS 3.14.11. I can build other modules that depend on asyn just fine (like std).
Any ideas?
Emma
<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
- RE: Windows busy build error - epics 3.14.12.1 Mark Rivers
asyn training at the EPICS Collaboration Meeting next week Mark Rivers
How to apply for Java SWT DateTime widget in CSS OPI? [SEC=UNCLASSIFIED] WANG, Jian
<2012>
<2012>
