Dear EPICS experts,
I'm using a custom record which is enhanced version of subroutine record
(has more output fields).
The record is not processed, besides it has a "2 second" set in the SCAN
field.
The scanppl doesn't show it has my custom records in the list.
The printouts I made in the
$EPICS_BASE/src/db/dbAccess.c:dbProcess(struct dbCommon *precord) are
not showing up. Which means dbProcess is not reached either.
The PACT field shows value 0. Setting it to 1 using caput doesn't seems
to change the value.
At the same time the function from INAM field of record is called
successfully and works fine.
Do You have a clue, how can I find out why dbProcess and consequently my
function supplied by SNAM is not called?
With Thanks in Advance,
Nerses
RE: Channel Access problem over SSH michael.abbott
Re: log message filter in Asyn Andrew Johnson
<2012>
Re: log message filter in Asyn Eric Norum
Re: How to debug record processing? Andrew Johnson
<2012>
