1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: RTEMS-MVME2300
To: Qazi Zia-ul-Haque <[email protected]>
Date: Thu, 12 Jan 2012 08:41:56 -0800
The problem is with a compile for the host machine, not a cross-compile  --  the actual cross-development target is irrelevant.  Janet's suggestion is correct.
On Jan 12, 2012, at 7:36 AM, Janet Anderson wrote:
> Your readline library may need ncurses.
> Try commenting out the "COMMANDLINE_LIBRARY=READLINE" line
> and uncommenting the "COMMANDLINE_LIBRARY=READLINE_NCURSES" line
> in base/configure/CONFIG_SITE.Common.linux-x86.
> Janet
Eric Norum
[email protected]
Re: RTEMS-MVME2300 Janet Anderson
Prev: Re: RTEMS-MVME2300 Janet Anderson
Next: RE: Does areaDetector Prosilica driver support Manta-series camera ? Davidsaver, Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: assert(!epicsThreadPrivateGet(caClientContextId)) failed when loading mrfioc2 王林
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
