1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: pyepics: Strategies for working with fast-changing large arrays
To: [email protected]
Cc: Anton Derbenev <[email protected]>
Date: Wed, 11 Jan 2012 16:18:19 -0600
Hi Andrew, Anton, Mark,
On Wed, Jan 11, 2012 at 11:30 AM, Andrew Johnson <[email protected]> wrote:
> Hi Anton,
> On 2012-01-11 Anton Derbenev wrote:
>> When I add a callback for a PV object with array
>>  data within, I become "subscribed" to the entire array. The problem may be
>>  that, as described below, the PV image data is always seen as large as (in
>>  my case) 1228800 elements array, while the actual region of interest size
>>  can be much smaller (all irrelevant elements of the array simply being set
>>  to 0). So, is it possible to create the PV object and the callback for it
>>  that will only monitor the specified part of itself (like, I assume,
>>  camonitor -# does)?
> Assuming that you're using EPICS Base version 3.14.12.1 or later the
> underlying CA library and IOC server do support variable length arrays, but I
> don't know if or how pyepics handles them.  When calling the underlying CA
> library directly from C code if you request an array of zero elements in a
> get-callback or monitor request, you'll get sent the number of elements that
> currently appear in the IOC's array field with no zero padding added.  This
> approach is what the camonitor program uses, and if pyepics supports it you'll
> want to use this feature for maximum throughput of array data.
> Note that cainfo reports the size of the storage allocated for the array on
> the IOC, which is the maximum size the array can be.  It can't tell you how
> much data the array currently holds.
Yes, pyepics does support variable length arrays (when using
3.14.12.1).  A monitor will return the array without zero-padding if
only a portion of the array has changed.    If a PV is monitored,  a
pv.get() will also return the shortened array.   The PV should also
report the shorter number (NORD) for its 'count', while the full array
size (NELM) is in the 'nelm' field:
   >>> import epics
   >>> p = epics.PV('Py:double64k')
   >>> print len(p.get())
   65536
   >>> p.put(range(20))
   >>> print p.get()
   [  0.   1.   2.   3.   4.   5.   6.   7.   8.   9.  10.  11.  12.  13.  14.
     15.  16.  17.  18.  19.]
   >>> print p.count, p.nelm
   20 65536
   >>> print p
   <PV 'Py:double64k', count=20/65536, type=double, access=read/write>
If a PV is not monitored (which would be the default for large arrays,
though Anton has said he was explicitly setting them to be monitored),
 a pv.get() without specifying the count will return the full array,
possibly zero-padded.   But, if you do specify a count  with something
like  'pv.get(count=20)' it will pass that along to
ca_array_get_callback, and so also get the truncated array and
presumably much faster.
I have verified that using the areaDetector PVs   cam1:MinX,
cam1:MinY, cam1:SizeX, and cam1:SizeY (note: not the ROI values, but
those of cam1) does limit the array size of image1:ArrayData, and that
pyepics will see the appropriately reduced-sized array.    So, I think
that should work for Anton, provided he's using 3.14.12.1.
For arrays of up to about 1Mb at 5Hz or so, I get nearly ideal data
rates from a 1360x1024 Prosilica camera.  Above that, and for fast
data acquisition (say,  more than a few Hz), I do see dropped
callbacks, as Anton reports.  I haven't looked into this in great
detail, but it looks to me like the Python callback function passed to
ca_create_subscription() is not being called for every event.  I don't
know what is limiting that.
Cheers,
--Matt
Re: pyepics: Strategies for working with fast-changing large arrays Anton Derbenev
Re: pyepics: Strategies for working with fast-changing large arrays Andrew Johnson
Prev: StripTool equivalent in Qt? Emmanuel Mayssat
Next: Does areaDetector Prosilica driver support Manta-series camera ? Chen, Hsin-Wei
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: pyepics: Strategies for working with fast-changing large arrays Andrew Johnson
Next: RE: Strategies for working with fast-changing large arrays michael.abbott
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
