Hi Mark,
Here is the info you requested:
epics> asynReport 10
MksuServer multiDevice:No canBlock:Yes autoConnect:Yes
enabled:Yes connected:Yes numberConnects 1
nDevices 0 nQueued 0 blocked:No
asynManagerLock:No synchronousLock:No
exceptionActive:No exceptionUsers 0 exceptionNotifys 0
interposeInterfaceList
asynOctet pinterface 0x68efa0 drvPvt 0x8f70aa8
interfaceList
asynCommon pinterface 0x68e05c drvPvt 0x8f27858
asynOctet pinterface 0x8f278a0 drvPvt 0x8f27858
Port 194.168.0.21:56789 UDP: Connected
fd: 4
Characters written: 0
Characters read: 0
Mksu multiDevice:Yes canBlock:Yes autoConnect:Yes
nDevices 1 nQueued 0 blocked:No
interfaceList
asynCommon pinterface 0x68f12c drvPvt 0x8f70cf8
asynDrvUser pinterface 0x68f204 drvPvt 0x8f70cf8
asynInt32 pinterface 0x68f138 drvPvt 0x8f70cf8
asynInt16Array pinterface 0x68f1b4 drvPvt 0x8f70cf8
addr 0 autoConnect Yes enabled Yes connected No exceptionActive No
exceptionActive No exceptionUsers 0 exceptionNotifys 0
blocked No
Mksu: missing report - MksuServer
Port: Mksu
Parameter list 0
Number of parameters is: 4
Parameter 0 type=asynInt32, name=WF_TRIG_DELAY_WRITE, value is undefined
Parameter 1 type=asynInt32, name=MOD_TRIG_DELAY_WRITE, value is undefined
Parameter 2 type=asynInt32, name=WF_TRIG_DELAY_READ, value is undefined
Parameter 3 type=asynInt32, name=MOD_TRIG_DELAY_READ, value is undefined
epics> dbpr KLYS:IN20:3130:WF_TRIG_DELAY_WRITE 10
ACKS: NO_ALARM ACKT: YES ADEL: 0 ALST: 0
AOFF: 0 ASG: ASLO: 0 ASP: (nil)
BKPT: 00 DESC: Waveform trigger delay (write) DISA: 0
DISP: 0 DISS: NO_ALARM DISV: 1 DOL:CONSTANT
DPVT: (nil) DRVH: 0 DRVL: 0 DSET: 0x68f470
DTYP: asynInt32 EGU: EGUF: 0 EGUL: 0
EOFF: 0 ESLO: 1 EVNT: 0 FLNK:CONSTANT 0
HHSV: NO_ALARM HIGH: 0 HIHI: 0 HOPR: 0
HSV: NO_ALARM HYST: 0 INIT: 1
IVOA: Continue normally IVOV: 0 LALM: 0
LBRK: 0 LCNT: 0 LINR: NO CONVERSION LLSV: NO_ALARM
LOLO: 0 LOPR: 0 LOW: 0 LSET: 0x8f7d120
LSV: NO_ALARM MDEL: 0
MLIS: 00 00 00 00 00 00 00 00 00 00 00 00 MLOK: 40 46 f7 08
MLST: 0 NAME: KLYS:IN20:3130:WF_TRIG_DELAY_WRITE
NSEV: NO_ALARM NSTA: NO_ALARM OIF: Full OMOD: 0
OMSL: supervisory ORAW: 0 ORBV: 0 OROC: 0
OUT:INST_IO @asyn(Mksu 0 1)WF_TRIG_DELAY_WRITE OVAL: 0
PACT: 0 PBRK: (nil) PHAS: 0 PINI: NO
PPN: (nil) PPNR: (nil) PREC: 0 PRIO: LOW
PROC: 0 PUTF: 0 PVAL: 0 RBV: 0
RDES: 0x8f2f7f8 ROFF: 0 RPRO: 0 RSET: 0x25a8e0
RVAL: 0 SCAN: Passive SDIS:CONSTANT SEVR: <nil>
SIML:CONSTANT SIMM: NO SIMS: NO_ALARM SIOL:CONSTANT
SPVT: 0x8f74b40 STAT: UDF TIME: <undefined> TPRO: 0
TSE: 0 TSEL:CONSTANT UDF: 0 VAL: 0
epics>
File mksu.template:
record(ao, "KLYS:$(AREA):$(LOCATION):WF_TRIG_DELAY_WRITE") {
field(DESC, "Waveform trigger delay (write)")
field(DTYP, "asynInt32")
field(OUT, "@asyn($(PORT) $(CHANNEL) $(TIMEOUT))WF_TRIG_DELAY_WRITE")
field(SCAN, "$(SCAN)")
record(ao, "KLYS:$(AREA):$(LOCATION):MOD_TRIG_DELAY_WRITE") {
field(OUT, "@asyn($(PORT) $(CHANNEL) $(TIMEOUT))MOD_TRIG_DELAY_WRITE")
field(DESC, "Remote modulator trigger delay (write)")
record(ai, "KLYS:$(AREA):$(LOCATION):WF_TRIG_DELAY_READ") {
field(INP, "@asyn($(PORT) $(CHANNEL) $(TIMEOUT))WF_TRIG_DELAY_READ")
field(DESC, "Waveguide trigger delay (read)")
record(ai, "KLYS:$(AREA):$(LOCATION):MOD_TRIG_DELAY_READ") {
field(INP, "@asyn($(PORT) $(CHANNEL) $(TIMEOUT))MOD_TRIG_DELAY_READ")
field(DESC, "Remote modulator trigger delay (read)")
File mksu.substitutions:
file ../../db/mksu.template
pattern
{AREA, LOCATION, PORT, CHANNEL, TIMEOUT, SCAN}
{IN20, 3130, Mksu, 0, 1, "I/O Intr"}
Luciano
-----Original Message-----
From: Mark Rivers [mailto:rivers@cars.uchicago.edu]
Sent: Thursday, November 24, 2011 05:05
To: Piccoli, Luciano; tech-talk@aps.anl.gov
Subject: RE: Asyn: "devAsynInt32::initCommon Link must be INST_IO"
Hi Luciano,
Can you send mksu.substitutions and whatever .template or .db files it loads?
What do you get at the IOC prompt for
asynReport 10
From: tech-talk-bounces@aps.anl.gov on behalf of Piccoli, Luciano
Sent: Wed 11/23/2011 5:56 PM
To: tech-talk@aps.anl.gov
Subject: Asyn: "devAsynInt32::initCommon Link must be INST_IO"
I'm writing a simple asyn driver which I started out from the HMS example. When starting the ioc I get these messages:
lpiccoli@cdlx22 iocMksu]$ ./st.cmd
#! ../../bin/linux-x86/example
dbLoadDatabase("../../dbd/example.dbd")
example_registerRecordDeviceDriver(pdbbase)
drvMksu_init()
drvAsynIPPortConfigure("MksuServer", "194.168.0.21:56789 UDP", 0, 0, 1)
initMksu("Mksu", "MksuServer")
dbLoadTemplate("mksu.substitutions")
iocInit()
Starting iocInit
## EPICS R3.14.10-lcls1 $R3-14-10$ $2008/10/27 19:39:04$
## EPICS Base built Jul 15 2009
KLYS:IN20:3130:MOD_TRIG_DELAY_READ devAsynInt32::initCommon Link must be INST_IO
KLYS:IN20:3130:WF_TRIG_DELAY_READ devAsynInt32::initCommon Link must be INST_IO
KLYS:IN20:3130:MOD_TRIG_DELAY_WRITE devAsynInt32::initCommon Link must be INST_IO
KLYS:IN20:3130:WF_TRIG_DELAY_WRITE devAsynInt32::initCommon Link must be INST_IO
epics>
It looks like something is not getting set correctly, the link type of those records should be INST_IO. Using gdb I see that they have the link type set to 0 (CONSTANT).
Am I missing something in the st.cmd file? Suggestions are welcome :)
Thank you,
Luciano
- RE: Asyn: "devAsynInt32::initCommon Link must be INST_IO" Mark Rivers
- Asyn: "devAsynInt32::initCommon Link must be INST_IO" Piccoli, Luciano
Re: [help] degree in Computer Science/Software Engineering Pavel Masloff
Re: gateway Andrew Johnson
<2011>
<2011>
