Hi Andrew,
Thank you for the assistance/info. Yes, you were correct. I've uncommented the makefile statement in question and it helped to resolve my problem. Bottom line, I am now able to successfully invoke the IOC.
Thanks again,
Flo
-----Original Message-----
Sent: Friday, August 05, 2011 2:18 PM
To: Cid, Florencio A
Cc: tech-talk@aps.anl.gov
Subject: Re: Erros running st.cmd
Hi Florencio,
On 2011-08-05 Cid, Florencio A wrote:
> Andrew, attached is the makefile you requested. Any help/assistance will
> be greatly appreciated.
It looks like you've tried to comment out stuff that you don't think you need,
but you actually do need one more thing. In particular you're not building
the firstioc_registerRecordDeviceDriver.cpp file into your binary, which
contains a static C++ constructor that registers all of the missing commands
with the IOC shell. You might be able to get away with not adding base.dbd to
firstioc_DBD if you get all of the necessary menu*.dbd files, but you
definitely need the above C++ source file in the firstioc_SRCS list.
Hopefully that fix will be enough to get you going.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- Erros running st.cmd Cid, Florencio A
- Re: Erros running st.cmd Andrew Johnson
- RE: Erros running st.cmd Cid, Florencio A
RE: Steven Banks passed away last night Andrew C. Starritt
Multi-threaded CAJ Example Ryan Slominski
<2011>
Steven Banks passed away last night Richard Farnsworth
<2011>
