g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Subject: EPICS OSI and events
To: <tech-talk@aps.anl.gov>
Date: Mon, 18 Jul 2011 13:05:32 +0000
I've found myself writing the slightly clunky block of code below and was wondering whether the gap in the OSI library thus revealed is readily fixed and worth fixing, or whether I've missed a more direct way to do this.
I have a number of threads that need to block until iocInit has finished initialisation, so the natural solution is to use initHookRegister() and block until initHookAtEnd occurs.  I can't safely call initHookRegister() for each waiting thread, because I might be too late, so it's simplest to call it once and signal everybody when the desired event occurs ... and there appears to be no straightforward way to do this, no mechanism equivalent to pthread_cond_broadcast().
I attach the code I've had to write.  Have I missed a simpler way to do this?  (Note, I've not run this code yet, so there may be some stupid bug in it.)
Assuming I've not missed anything in OSI this begs the question of whether OSI can readily be extended to support pthread condition variables or something equivalent, whether the associated implementations are feasible, and whether this is worth doing.
I found this page interesting: http://borkhuis.home.xs4all.nl/vxworks/vxw_pt5.html#5.5  Section 5.5 says "pthreads [have been ported] from Linux to VxWorks ... The only thing missing is condition variables.  They turned out to be kind of hard."  I'm sure this problem has been visited before, but thought I ought to comment.
---- epics_ready.h ----
/* Simple API for blocking until EPICS has finished initialisation. */
/* Must be called early, both before any call to wait_for_epics_ready() and
 * before iocInit has been called. */
void initialise_epics_ready(void);
/* If EPICS hasn't finished startup this will block until done. */
void wait_for_epics_ready(void);
---- epics_ready.c ----
#include <stdbool.h>
#include <stdlib.h>
#include <epicsEvent.h>
#include <epicsMutex.h>
#include <initHooks.h>
#include "epics_ready.h"
/* Set once EPICS startup has completed. */
static bool epics_ready = false;
/* Used to guard access to the waiting list. */
static epicsMutexId epics_ready_mutex;
/* Alas the EPICS OSI does not appear to provide any mechanism (akin to the
 * pthread condition variable) for waking more than one waiting thread at a
 * time.  So here we roll our own waiting list.  Note that the waiters are woken
 * in reverse order of waiting, but I don't care (easy to fix). */
static struct epics_ready_waiter {
    struct epics_ready_waiter *next;
    epicsEventId event;
} *epics_ready_list = NULL;
static void epics_init_hook(initHookState state)
    if (state == initHookAtEnd)
        struct epics_ready_waiter *waiter, *next;
        epicsMutexMustLock(epics_ready_mutex);
        epics_ready = true;
        for (waiter = epics_ready_list; waiter != NULL; waiter = next)
            /* Note that calling epicsEventSignal() may invalidate waiter, so
             * have to pick up next pointer first. */
            next = waiter->next;
            epicsEventSignal(waiter->event);
        epicsMutexUnlock(epics_ready_mutex);
    if (!epics_ready)
        struct epics_ready_waiter *waiter = NULL;
        if (!epics_ready)
            waiter = malloc(sizeof(struct epics_ready_waiter));
            waiter->event = epicsEventMustCreate(epicsEventEmpty);
            waiter->next = epics_ready_list;
            epics_ready_list = waiter;
        if (waiter != NULL)
            epicsEventMustWait(waiter->event);
            epicsEventDestroy(waiter->event);
            free(waiter);
    epics_ready_mutex = epicsMutexMustCreate();
    initHookRegister(epics_init_hook);
By contrast, here is exactly the same functionality implemented using pthread condition variables:
---- epics_ready_pthread.c ----
#include <stdlib.h>
#include <pthread.h>
/* An pthread condition has to come with an associated mutex. */
static pthread_mutex_t epics_ready_mutex = PTHREAD_MUTEX_INITIALIZER;
static pthread_cond_t epics_ready_cond = PTHREAD_COND_INITIALIZER;
        pthread_mutex_lock(&epics_ready_mutex);
        epics_ready = true;
        pthread_cond_broadcast(&epics_ready_cond);
        pthread_mutex_unlock(&epics_ready_mutex);
    if (!epics_ready)
        while (!epics_ready)
            pthread_cond_wait(&epics_ready_cond, &epics_ready_mutex);
RE: EPICS OSI and events Mark Rivers
Prev: Delay problem in ca_array_put() command Perrier Pierre
Next: RE: EPICS OSI and events Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Prev: RE: Delay problem in ca_array_put() command Jeff Hill
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
