g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Subject: Delay problem in ca_array_put() command
To: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Mon, 18 Jul 2011 07:45:55 +0000
Hi everybody,
I 'm working on a IOC or Portable CA Server capable of managing other IOC in order to sequence them, for instance. Typically this IOC controls multiple motors, each represented by an IOC.
I don’t know which type of implementation (Portable CA Server or IOC) is the most efficient. In this case, I started implementing an IOC. is it a good choice ?
More particularly, I’ve a problem with the part of this IOC acting as the client of the others IOC it controls. This client monitors  a few PV of the motor’s IOC and all seems ok. It’s a multi-threaded client. I’ve created my CA context with :
                                ca_context_create(ca_enable_preemptive_callback);
And to be notified of change events, I’ve created a thread to launch :
ca_pend_event (0.0);
The problem occurs when I want to change a PV value. All seems ok but the pv is only really modified 30 seconds to 1 min after the call to ca_array_put (I have tested this in localhost) . To change a value, I proceed in the following manner for a double :
                               ca_array_put(DBR_DOUBLE, 1, channel, &val);
status=ca_pend_io(put_timeout);
Is this a normal behaviour? If not, how can this issue be solved?
Thanks in advance,
Best regards,
Pierre PERRIER
Stagiaire - MCO LIL
Sopra group.
Parc Innolin
9 rue du Golf 33700 Merignac
Phone : +33 (0)5 56 12 79 59
piperrier@sopragroup.com - www.sopragroup.com
Ce message peut contenir des informations confidentielles dont la divulgation est à ce titre rigoureusement interdite en l'absence d'autorisation explicite de l'émetteur. Dans l'hypothèse où vous auriez reçu par erreur ce message, merci de le renvoyer à l’émetteur et de détruire toute copie.
P Pensez à l’environnement avant d’imprimer.
RE: Delay problem in ca_array_put() command Jeff Hill
Prev: RE: streamdevice + asyn stuck Zhang, Dehong
Next: EPICS OSI and events michael.abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Prev: Announce: sequencer release 2.1.0 Benjamin Franksen
Next: RE: Delay problem in ca_array_put() command Jeff Hill
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
