g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Subject: minimum CA Server requirements
From: Circuit6 Engineering <circuit6engineering@gmail.com>
To: tech-talk@aps.anl.gov
Date: Thu, 30 Jun 2011 20:25:06 -0400
I am very new to EPICS and only just started to work my way through the lectures, documentation and program text. I wonder how lean and trim a channel access server could be? For example, is it ridiculous to think about running CA Server on a 100MHz ARM Cortex-M3 with 256 KB flash memory, 64 KB SRAM and 10/100 Mbps Ethernet?
I am also very new to RTEMS. If RTEMS is too heavy for a minimal hardware environment, could a trim CA server be ported to FreeRTOS with the lwIP (Lightweight IP) stack without serious re-engineering?
Thanks for any comments, speculations or pointers to reference materials!
Re: minimum CA Server requirements Andrew Johnson
Prev: Re: Does EPICS Base support multi-thread on vxWorks 6.3? Andrew Johnson
Next: RE: SNL seq-2.0.13 on Linux 64 bits: not all monitored PVs receive their first monitor event Utzel Nadine
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Prev: Re: EPICS Soft IOC hardware switch Eric Norum
Next: Re: minimum CA Server requirements Andrew Johnson
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
