g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Subject: Windows XP Cygwin difficulties for building EPICS base
From: "Cid, Florencio A" <florencio.a.cid@boeing.com>
To: "'tech-talk@aps.anl.gov'" <tech-talk@aps.anl.gov>
Date: Mon, 23 May 2011 16:52:53 -0700
I’m a beginner with EPICS.
I’m trying to build EPICS base (3.14.12.1) on Windows XP with Cygwin (EPICS_HOST_ARCH = cygwin-x86, SHARED_LIBRARIES = NO, STATIC_BUILD = YES).   I get pretty far into the build, but encounter the following error for  directory src/cap5 (see below).
make[3]: Leaving directory `/cygdrive/c/EPICS/base/src/excas/O.cygwin-x86'
make[2]: Leaving directory `/cygdrive/c/EPICS/base/src/excas'
make -C ./cap5 install
make[2]: Entering directory `/cygdrive/c/EPICS/base/src/cap5'
perl ../../bin/cygwin-x86/makeMakefile.pl O.cygwin-x86 ../../..
mkdir O.Common
make -C O.cygwin-x86 -f ../Makefile TOP=../../.. T_A=cygwin-x86 install
make[3]: Entering directory `/cygdrive/c/EPICS/base/src/cap5/O.cygwin-x86'
rm -f CA.html
podchecker ../CA.pm && pod2html --infile=../CA.pm --outfile=CA.html
/bin/sh: /usr/bin/podchecker: /usr/bin/perl: bad interpreter: No such file or di
rectory
make[3]: *** [CA.html] Error 126
make[3]: Leaving directory `/cygdrive/c/EPICS/base/src/cap5/O.cygwin-x86'
make[2]: *** [install.cygwin-x86] Error 2
make[2]: Leaving directory `/cygdrive/c/EPICS/base/src/cap5'
make[1]: *** [cap5.install] Error 2
make[1]: Leaving directory `/cygdrive/c/EPICS/base/src'
make: *** [src.install] Error 2
Any help/assistance will be greatly appreciated.
Thanks in advance,
Florencio Cid
Re: Windows XP Cygwin difficulties for building EPICS base Dirk Zimoch
Re: Windows XP Cygwin difficulties for building EPICS base Andrew Johnson
Prev: Re: vxWorks network problems Andrew Johnson
Next: Device Support for Nemic Lambda Power Supplies Anthony Andrews
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Prev: Re: When a record is changed twice very fast, camonitor only detects first change Andrew Johnson
Next: Re: Windows XP Cygwin difficulties for building EPICS base Dirk Zimoch
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
