g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Subject: Problem building 3.14.12.1 on cygwin-x86
To: "Janet Anderson" <jba@aps.anl.gov>
Cc: EPICS Tech Talk <tech-talk@aps.anl.gov>
Date: Fri, 20 May 2011 17:41:58 -0500
Hi Janet,
I’m having trouble building "antelope" on cygwin-x86 under 3.14.12.1.  It works fine under 3.14.12.
Here is the output of the final link command under 3.14.12
$ make
g++ -o antelope.exe -static -Lh:/epics/base-3.14.12/lib/cygwin-x86       -m32                closure.o error.o lalr.o lr0.o main.o mkpar.o o
utput.o reader.o skeleton.o symtab.o verbose.o warshall.o   -lCom   -lpthread   -lreadline -lcurses -lm
Installing created file ../../../../bin/cygwin-x86/antelope.exe
make[1]: Leaving directory `/cygdrive/h/epics/base-3.14.12/src/toolsComm/antelope/O.cygwin-x86'
Here is the output under 3.14.12.1
g++ -o antelope.exe -static -Lh\:/epics/base-3.14.12.1/lib/cygwin-x86       -m32                closure.o error.o lalr.o lr0.o main.o mkpar.
o output.o reader.o skeleton.o symtab.o verbose.o warshall.o   -lCom   -lpthread   -lreadline -lcurses -lm
/usr/lib/gcc/i686-pc-cygwin/3.4.4/../../../../i686-pc-cygwin/bin/ld: cannot find -lCom
collect2: ld returned 1 exit status
make[1]: *** [antelope.exe] Error 1
make[1]: Leaving directory `/cygdrive/h/epics/base-3.14.12.1/src/toolsComm/antelope/O.cygwin-x86'
make: *** [install.cygwin-x86] Error 2
The difference is that under 3.14.12 the command produced has “-Lh:/epics/base-3.14.12/lib/cygwin-x86”, while under 3.14.12.1 it has “-Lh\:/epics/base-3.14.12.1/lib/cygwin-x86”, i.e. it has an extra backslash.
I am compiling this under the Cygwin bash shell.
The cygwin configuation files in configure/os are identical in the 3.14.12 and 3.14.12.1 directories.
Prev: RE: problem with gateway and softIoc running on same server Kevin Tsubota
Next: CAJ Flow Control Bug David Brodrick
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Prev: RE: trouble with 64-bit Window7 Mark Rivers
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
