g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Subject: problem with gateway and softIoc running on same server
To: <tech-talk@aps.anl.gov>
Date: Wed, 18 May 2011 17:49:03 -1000
I want a gateway to publish PVs from 192.168.134.51:8064 which is on a private network connected to 192.171.95.112 (where a softIoc is already running) because I can’t access this private
I have the situation where I have a solaris-8 server (192.171.95.112) with two network cards.  One goes to our observatory network and the other goes to a private network running a windows based softIoc (192.168.134.51).  Now I need access to the PVs of the widows softIoc from other IPs on the observatory network.
I can successfully get the gateway to publish the windows softIoc PVs without any problems.  However, I have a solaris softIoc running on the same server as the gateway and this is where I’m having problems. I’ve tried using different EPICS_CA_SERVER_PORTS for both IOCs but no matter what I try I can’t get the gateway to see the solaris IOC on the same IP.  If I manually set my EPICS_CA_SERVER_PORT at the command line then issue a caget, it successfully returns the PV value but it reports that there’s multiple instances of the PV.
My question is: can a gateway co-exist with a softIoc in the same ip address?
If so, what do I need to do to make it happen?  Using different EPICS_CA_SERVER_PORTs doesn’t seem to be it.  Is this related to the fact that I can’t run multiple softIocs on the same server unless I change port numbers?  In which case I’d want a gateway to interface to them as well.
Here’s my startup command run on the solaris server (128.171.95.112):
/usr/local/epics/r3.14.9/extensions/bin/solaris-sparc-gnu/gateway -debug 1 -pvlist k1lmct.pvlist -access GATEWAY.access -home $HOME -log k1lmct.log -sip "128.171.95.112" -sport 5064 -cip "192.171.95.112:8164 192.168.134.51:8064" -prefix k1:lmct:gateway&
Here’s the start of the debug output log:
PV Gateway Version 2.0.3.0 [Feb 20 2008 16:27:23]
EPICS 3.14.9 PID=13539
EPICS_CA_ADDR_LIST=192.171.95.112:8164 192.168.134.51:8064
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_CA_SERVER_PORT=Not specified
EPICS_CA_MAX_ARRAY_BYTES=Not specified
EPICS_CAS_INTF_ADDR_LIST=128.171.95.112
EPICS_CAS_SERVER_PORT=5064
EPICS_CAS_IGNORE_ADDR_LIST=Not specified
Thank you in advance!
Kevin Tsubota
W.M. Keck Observatory
Re: problem with gateway and softIoc running on same server Dirk Zimoch
Re: problem with gateway and softIoc running on same server Ralph Lange
Prev: Re: Visit of SLAC/ALS control room? emmanuel_mayssat
Next: Re: problem with gateway and softIoc running on same server Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Prev: RE: multi-threaded client example Jeff Hill
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
