I've been having trouble with one linux machine where my IOC's appear
to be running correctly, dbgf works from iocsh, but caget from another
window on the same machine fails to connect. I suspect it has something
to do with how the multiple interfaces on this machine are configured, but
so far have been unable to find a solution.
# ifconfig
eth0 Link encap:Ethernet HWaddr 00:1E:68:79:5C:4E
inet addr:134.79.32.161 Bcast:134.79.35.255 Mask:255.255.252.0
inet6 addr: fe80::21e:68ff:fe79:5c4e/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:190759 errors:0 dropped:0 overruns:0 frame:0
TX packets:43567 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:18427912 (17.5 MiB) TX bytes:9772031 (9.3 MiB)
Interrupt:19
eth2 Link encap:Ethernet HWaddr 00:1E:68:79:5C:50
inet addr:192.168.254.2 Bcast:192.168.254.255 Mask:255.255.255.0
inet6 addr: fe80::21e:68ff:fe79:5c50/64 Scope:Link
RX packets:1238443 errors:0 dropped:0 overruns:0 frame:0
TX packets:879202 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:80539799 (76.8 MiB) TX bytes:64420869 (61.4 MiB)
Interrupt:20 Base address:0x4000
Gateway is 134.79.35.1
I'm running with defaults for the EPICS_CA* and EPICS_CAS* env variables,
but have also played with EPICS_CA_ADDR_LIST, EPICS_CA_AUTO_ADDR_LIST,
and EPICS_CA_INTF_ADDR_LIST with no success.
See attached files for casr, epicsEnvShow, ifconfig, and netstat output
for more configuration details. We're running base 3.14.9
everywhere, but this
is the only machine showing this problem.
The casr output includes:
UDP Server:
UDP 0.0.0.0:0(): User="", V4.0, 0 Channels, Priority=0
This looks wrong to me, as my working IOC's show a valid UDP addr, but I'm
not sure how to fix this, or even if this is the root problem.
Any suggestions would be appreciated.
- Bruce
P.S. When I run caget, tcpdump shows:
# /usr/sbin/tcpdump -i eth0 -n -nn udp dst portrange 5064-5065
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 96 bytes
21:46:55.934345 IP 192.168.254.2.54260 > 134.79.35.255.5065: UDP, length 16
21:46:57.179960 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP, length 48
21:46:57.211939 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP, length 48
21:46:57.275932 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP, length 48
21:46:57.403935 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP, length 48
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA 94025
RX packets:169272 errors:0 dropped:0 overruns:0 frame:0
TX packets:40902 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:16253702 (15.5 MiB) TX bytes:9295274 (8.8 MiB)
Interrupt:19
RX packets:1183083 errors:0 dropped:0 overruns:0 frame:0
TX packets:840829 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:76937113 (73.3 MiB) TX bytes:61771629 (58.9 MiB)
eth3 Link encap:Ethernet HWaddr 00:1E:68:79:5C:51
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
Interrupt:23 Base address:0x6000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:254294 errors:0 dropped:0 overruns:0 frame:0
TX packets:254294 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:870404912 (830.0 MiB) TX bytes:870404912 (830.0 MiB)
EDMOBJECTS=/reg/g/pcds/package/epics/3.14/extensions/current/templates/edm
EPICS_SITE_TOP=/reg/g/pcds/package/epics/3.14
HOSTNAME=bl13-ejb.slac.stanford.edu
GATEWAY_MODULE_VERSION=current
SHELL=/bin/bash
TERM=xterm
HISTSIZE=1000
EDMHELPFILES=/reg/g/pcds/package/epics/3.14/extensions/current/helpFiles
TST_SUBNET=42
BASE_MODULE_VERSION=current
EDMPVOBJECTS=/reg/g/pcds/package/epics/3.14/extensions/current/templates/edm
USER=rci
LD_LIBRARY_PATH=:/reg/g/pcds/package/epics/3.14/base/current/lib/linux-x86_64:/reg/g/pcds/package/epics/3.14/extensions/current/lib/linux-x86_64
LS_COLORS=no=00:fi=00:di=00;34:ln=00;36:pi=40;33:so=00;35:do=00;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=01;05;37;41:su=37;41:sg=30;43:tw=30;42:ow=34;42:st=37;44:ex=00;32:*.cmd=00;32:*.exe=00;32:*.com=00;32:*.btm=00;32:*.bat=00;32:*.sh=00;32:*.csh=00;32:*.tar=00;31:*.tgz=00;31:*.svgz=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.lzma=00;31:*.zip=00;31:*.z=00;31:*.Z=00;31:*.dz=00;31:*.gz=00;31:*.bz2=00;31:*.tbz2=00;31:*.bz=00;31:*.tz=00;31:*.deb=00;31:*.rpm=00;31:*.jar=00;31:*.rar=00;31:*.ace=00;31:*.zoo=00;31:*.cpio=00;31:*.7z=00;31:*.rz=00;31:*.jpg=00;35:*.jpeg=00;35:*.gif=00;35:*.bmp=00;35:*.pbm=00;35:*.pgm=00;35:*.ppm=00;35:*.tga=00;35:*.xbm=00;35:*.xpm=00;35:*.tif=00;35:*.tiff=00;35:*.png=00;35:*.mng=00;35:*.pcx=00;35:*.mov=00;35:*.mpg=00;35:*.mpeg=00;35:*.m2v=00;35:*.mkv=00;35:*.ogm=00;35:*.mp4=00;35:*.m4v=00;35:*.mp4v=00;35:*.vob=00;35:*.qt=00;35:*.nuv=00;35:*.wmv=00;35:*.asf=00;35:*.rm=00;35:*.rmvb=00;35:*.flc=00;35:*.avi=00;35:*.fli=00;35:*.gl=00;35:*.dl=00;35:*.xcf=00;35:*.xwd=00;35:*.yuv=00;35:*.svg=00;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:
CDS_SUBNET=35
RUNUSER=/bin/bash -c
VDCT_CLASSPATH=/reg/g/pcds/package/epics/3.14/extensions/current/javalib/VisualDCT.jar
TOOLS_MODULE_VERSION=current
PROCSERV=/reg/g/pcds/package/procServ-2.4.0/procServ --allow --ignore ^D^C
MAIL=/var/spool/mail/rci
PATH=/usr/kerberos/bin:/usr/local/bin:/bin:/usr/bin:/reg/g/pcds/package/epics/3.14/base/current/bin/linux-x86_64:/reg/g/pcds/package/epics/3.14/tools/current/bin:/reg/g/pcds/package/epics/3.14/extensions/current/bin/linux-x86_64:/home/rci/bin
_=/reg/g/pcds/package/procServ-2.4.0/procServ
EDMLIBS=/reg/g/pcds/package/epics/3.14/extensions/current/lib/linux-x86_64
EDMFILES=/reg/g/pcds/package/epics/3.14/extensions/current/templates/edm
EPICS_SITE_CONFIG=/reg/g/pcds/package/epics/3.14/RELEASE_SITE
INPUTRC=/etc/inputrc
PWD=/reg/g/pcds/package/epics/3.14/ioc/sxr/rci/usbMotors/current/iocBoot/ioc-sxr-rci-usb
IOC_DATA=/reg/d/iocData/
SXR_SUBNET=39
MGT_SUBNET=24
LANG=en_US.UTF-8
SUBNET=32
XPP_SUBNET=38
EDMUSERLIB=/reg/g/pcds/package/epics/3.14/extensions/current/lib/linux-x86_64
SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
SHLVL=5
HOME=/home/rci
IOC=ioc-sxr-rci-usb
IOC_HOST=bl13-ejb
FEE_SUBNET=36
EXTENSIONS_MODULE_VERSION=current
EDMWEBBROWSER=mozilla
LOGNAME=rci
EPICS_TOOLS_SITE_TOP=/reg/g/pcds/package/epics/3.14
EDMFILTERS=/reg/g/pcds/package/epics/3.14/extensions/current/templates/edm
AMO_SUBNET=37
LESSOPEN=|/usr/bin/lesspipe.sh %s
CA_BIN=/reg/g/pcds/package/epics/3.14/base/current/bin/linux-x86_64
DISPLAY=localhost:11.0
IP=134.79.32.161
192.168.254.2
VDCT_MODULE_VERSION=current
G_BROKEN_FILENAMES=1
ENGINEER=Bruce Hill (bhill)
LOCATION=SXR:RCI:IOC:USB
IOCSH_PS1=ioc-sxr-rci-usb>
ARCH=linux-x86
TOP=/data/epics/3.14/ioc/sxr/rci/usbMotors/current
EPICS_MODULES=/reg/g/pcds/package/epics/3.14/modules
EPICS_BASE=/reg/g/pcds/package/epics/3.14/base/R3.14.9-0.3.0
AUTOSAVE=/reg/g/pcds/package/epics/3.14/modules/autosave/R4.2.1.2-1.1.0
IOCADMIN=/reg/g/pcds/package/epics/3.14/modules/iocAdmin/R2.0.0-1.1.0
ASYN=/reg/g/pcds/package/epics/3.14/modules/asyn/R4.10.1-1.0.0
MOTOR=/reg/g/pcds/package/epics/3.14/modules/motor/R6.4.4-1.7.0
EPICS_TS_NTP_INET=psntp.slac.stanford.edu
EPICS_IOC_LOG_PORT=7004
EPICS_IOC_LOG_INET=psloghost.slac.stanford.edu
EPICS_IOC_LOG_FILE_LIMIT=1000000
EPICS_IOC_LOG_FILE_COMMAND=
EPICS_CA_ADDR_LIST=
EPICS_CA_REPEATER_PORT=5065
EPICS_CA_SERVER_PORT=5064
EPICS_CA_CONN_TMO=10.0
EPICS_CA_BEACON_PERIOD=5.0
EPICS_CA_MAX_SEARCH_PERIOD=60.0
EPICS_CA_AUTO_ADDR_LIST=YES
EPICS_CAS_INTF_ADDR_LIST=
EPICS_CAS_BEACON_ADDR_LIST=
EPICS_CAS_AUTO_BEACON_ADDR_LIST=
EPICS_CAS_SERVER_PORT=
EPICS_CAS_BEACON_PORT=
EPICS_CAS_BEACON_PERIOD=5.0
EPICS_CA_MAX_ARRAY_BYTES=4000000
STREAM_PROTOCOL_PATH=protocol
LINES=24
COLUMNS=80
ioc-sxr-rci-usb> casr 2
Channel Access Server V4.11
No clients connected.
UDP Server:
Task Id=0x8ea1e28, Socket FD=10
Secs since last send 8225.52, Secs since last receive 8225.52
Unprocessed request bytes=16, Undelivered response bytes=0
State=up
180 bytes allocated
There are currently 1260 bytes on the server's free list
7 client(s), 0 channel(s), 0 event(s) (monitors) 0 putNotify(s)
0 small buffers (16384 bytes ea), and 0 jumbo buffers (4000024 bytes ea)
The server's array size limit is 4000024 bytes max
Channel Access Address List
192.168.254.255:5065
134.79.35.255:5065
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 0.0.0.0:33632 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:40001 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:30050 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:5064 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:3306 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:30000 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:30001 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:6010 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:43931 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:6011 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:37916 0.0.0.0:* LISTEN
tcp 0 0 192.168.254.2:51042 192.168.254.101:2108 ESTABLISHED
tcp 0 0 192.168.254.2:38556 192.168.254.101:2104 ESTABLISHED
tcp 0 0 192.168.254.2:37630 192.168.254.101:2114 ESTABLISHED
tcp 0 0 192.168.254.2:37638 192.168.254.101:2109 ESTABLISHED
tcp 0 0 192.168.254.2:35860 192.168.254.101:2101 ESTABLISHED
tcp 0 0 192.168.254.2:34894 192.168.254.101:2105 ESTABLISHED
tcp 0 0 134.79.32.161:22 134.79.32.130:4002 ESTABLISHED
tcp 0 0 192.168.254.2:54953 192.168.254.101:2107 ESTABLISHED
tcp 0 0 192.168.254.2:55470 192.168.254.101:2112 ESTABLISHED
tcp 0 0 134.79.32.161:22 134.79.72.91:54486 ESTABLISHED
tcp 0 0 134.79.32.161:22 134.79.72.91:46773 ESTABLISHED
tcp 0 0 192.168.254.2:38144 192.168.254.101:2103 ESTABLISHED
tcp 0 0 192.168.254.2:45607 192.168.254.101:2102 ESTABLISHED
tcp 0 0 192.168.254.2:36498 192.168.254.101:2110 ESTABLISHED
tcp 0 0 192.168.254.2:45502 192.168.254.101:2106 ESTABLISHED
tcp 0 0 192.168.254.2:44382 192.168.254.101:2113 ESTABLISHED
tcp 0 0 :::45122 :::* LISTEN
tcp 0 0 :::48905 :::* LISTEN
tcp 0 0 ::ffff:127.0.0.1:33578 :::* LISTEN
tcp 0 0 :::3820 :::* LISTEN
tcp 0 0 :::48974 :::* LISTEN
tcp 0 0 :::8686 :::* LISTEN
tcp 0 0 :::4848 :::* LISTEN
tcp 0 0 :::8080 :::* LISTEN
tcp 0 0 :::3920 :::* LISTEN
tcp 0 0 :::3700 :::* LISTEN
tcp 0 0 :::8181 :::* LISTEN
tcp 0 0 :::22 :::* LISTEN
tcp 0 0 :::40984 :::* LISTEN
tcp 0 0 :::51288 :::* LISTEN
tcp 0 0 ::1:6010 :::* LISTEN
tcp 0 0 :::56762 :::* LISTEN
tcp 0 0 ::1:6011 :::* LISTEN
tcp 0 0 :::7676 :::* LISTEN
tcp 0 0 ::ffff:134.79.32.161:47544 ::ffff:134.79.34.89:1000 ESTABLISHED
tcp 0 0 ::ffff:134.79.32.161:46212 ::ffff:134.79.34.89:1000 ESTABLISHED
tcp 40 0 ::ffff:192.168.254.2:58770 ::ffff:192.168.254.10:502 ESTABLISHED
tcp 0 0 ::ffff:192.168.254.2:58678 ::ffff:192.168.254.100:2104 ESTABLISHED
tcp 0 0 ::ffff:192.168.254.2:56091 ::ffff:192.168.254.100:2103 ESTABLISHED
tcp 0 0 ::ffff:134.79.32.161:50430 ::ffff:134.79.34.89:1000 ESTABLISHED
tcp 0 0 ::ffff:134.79.32.161:33522 ::ffff:134.79.34.89:1000 ESTABLISHED
tcp 0 0 ::ffff:192.168.254.2:35135 ::ffff:192.168.254.100:2102 ESTABLISHED
tcp 0 0 ::ffff:192.168.254.2:56779 ::ffff:192.168.254.100:2105 ESTABLISHED
udp 0 0 0.0.0.0:57221 0.0.0.0:*
udp 0 0 192.168.254.2:36998 134.79.35.255:5065 ESTABLISHED
udp 0 0 0.0.0.0:46476 0.0.0.0:*
udp 0 0 0.0.0.0:32909 0.0.0.0:*
udp 0 0 0.0.0.0:659 0.0.0.0:*
udp 0 0 127.0.0.1:52124 127.0.0.1:34605 ESTABLISHED
udp 0 0 0.0.0.0:39198 0.0.0.0:*
udp 0 0 0.0.0.0:59173 0.0.0.0:*
udp 0 0 0.0.0.0:34605 0.0.0.0:*
udp 0 0 0.0.0.0:43694 0.0.0.0:*
udp 0 0 0.0.0.0:5064 0.0.0.0:*
udp 0 0 0.0.0.0:35016 0.0.0.0:*
udp 0 0 0.0.0.0:5065 0.0.0.0:*
udp 0 0 192.168.254.2:35918 134.79.35.255:5065 ESTABLISHED
udp 0 0 192.168.254.2:44379 0.0.0.0:*
udp 0 0 0.0.0.0:608 0.0.0.0:*
udp 0 0 0.0.0.0:43493 0.0.0.0:*
udp 0 0 0.0.0.0:5353 0.0.0.0:*
udp 0 0 127.0.0.1:55277 127.0.0.1:43694 ESTABLISHED
udp 0 0 0.0.0.0:111 0.0.0.0:*
udp 0 0 192.168.254.2:54260 134.79.35.255:5065 ESTABLISHED
udp 0 0 0.0.0.0:56565 0.0.0.0:*
udp 0 0 :::53263 :::*
udp 0 0 :::41370 :::*
udp 0 0 :::49819 :::*
udp 0 0 :::45341 :::*
udp 0 0 :::59043 :::*
udp 0 0 :::60710 :::*
udp 0 0 :::36401 :::*
udp 0 0 :::41409 :::*
udp 0 0 :::36420 :::*
udp 0 0 :::44875 :::*
udp 0 0 :::38366 :::*
udp 0 0 :::54886 :::*
udp 0 0 :::35184 :::*
udp 0 0 :::52721 :::*
udp 0 0 :::45682 :::*
udp 0 0 :::40182 :::*
udp 0 0 :::42234 :::*
udp 0 0 :::56191 :::*
Active UNIX domain sockets (servers and established)
Proto RefCnt Flags Type State I-Node Path
unix 2 [ ACC ] STREAM LISTENING 8197 @/var/run/hald/dbus-XPPhnxy7GD
unix 2 [ ACC ] STREAM LISTENING 7543 /var/run/audispd_events
unix 2 [ ACC ] STREAM LISTENING 7649 /var/run/rpcbind.sock
unix 2 [ ACC ] STREAM LISTENING 8055 /var/run/dbus/system_bus_socket
unix 2 [ ] DGRAM 1673 @/com/ubuntu/upstart
unix 2 [ ACC ] STREAM LISTENING 9072 /var/run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 9498 /tmp/.X11-unix/X0
unix 2 [ ACC ] STREAM LISTENING 12991 /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix 2 [ ACC ] STREAM LISTENING 8172 /var/run/acpid.socket
unix 2 [ ACC ] STREAM LISTENING 13000 /tmp/orbit-rci/linc-aac-0-3584d2b966200
unix 2 [ ACC ] STREAM LISTENING 13006 /tmp/keyring-8XGSLO/socket
unix 2 [ ACC ] STREAM LISTENING 13008 /tmp/keyring-8XGSLO/ssh
unix 2 [ ACC ] STREAM LISTENING 13010 /tmp/keyring-8XGSLO/socket.pkcs11
unix 2 [ ACC ] STREAM LISTENING 13074 /tmp/ssh-MVFtCb2738/agent.2738
unix 2 [ ACC ] STREAM LISTENING 13177 /tmp/orbit-rci/linc-ab2-0-6313415bafe9f
unix 2 [ ACC ] STREAM LISTENING 9497 @/tmp/.X11-unix/X0
unix 2 [ ACC ] STREAM LISTENING 13182 /tmp/.ICE-unix/2738
unix 2 [ ACC ] STREAM LISTENING 13208 /tmp/orbit-rci/linc-aeb-0-38fb5be1c67e3
unix 2 [ ACC ] STREAM LISTENING 9627 @/tmp/gdm-session-ZfztANUC
unix 2 [ ACC ] STREAM LISTENING 13920 /tmp/.esd-504/socket
unix 2 [ ACC ] STREAM LISTENING 13927 /tmp/pulse-rci/native
unix 2 [ ACC ] STREAM LISTENING 13954 /tmp/orbit-rci/linc-af0-0-291584f2dff14
unix 2 [ ] DGRAM 2038 @/org/kernel/udev/udevd
unix 2 [ ACC ] STREAM LISTENING 14191 /tmp/orbit-rci/linc-af8-0-2a9c73557117d
unix 2 [ ACC ] STREAM LISTENING 14310 /tmp/orbit-rci/linc-b05-0-2ea2d3f7a45e4
unix 2 [ ACC ] STREAM LISTENING 14316 /tmp/orbit-rci/linc-b03-0-646c1b0a4955
unix 2 [ ACC ] STREAM LISTENING 14401 /tmp/orbit-rci/linc-b07-0-2ea2d3f7bd3df
unix 2 [ ACC ] STREAM LISTENING 14406 /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix 2 [ ACC ] STREAM LISTENING 14695 /tmp/orbit-rci/linc-b0d-0-374d9efed4dcf
unix 2 [ ACC ] STREAM LISTENING 14790 /tmp/orbit-rci/linc-b13-0-7550bfade1198
unix 2 [ ACC ] STREAM LISTENING 15070 /tmp/orbit-rci/linc-b12-0-2ea2d3f6231fb
unix 2 [ ACC ] STREAM LISTENING 15128 /tmp/orbit-rci/linc-b2b-0-5cc9ebe33f113
unix 2 [ ACC ] STREAM LISTENING 15163 /tmp/orbit-rci/linc-b2c-0-5cc9ebe34d01c
unix 2 [ ACC ] STREAM LISTENING 15249 /tmp/orbit-rci/linc-b2e-0-7e6c12606a520
unix 2 [ ACC ] STREAM LISTENING 15584 /tmp/orbit-rci/linc-b50-0-73693cbd64bf
unix 2 [ ACC ] STREAM LISTENING 15590 /tmp/orbit-rci/linc-b4a-0-73693cbd6ab5
unix 2 [ ACC ] STREAM LISTENING 15594 /tmp/orbit-rci/linc-b4c-0-73693cbd6ed7
unix 2 [ ACC ] STREAM LISTENING 15673 /tmp/orbit-rci/linc-b4e-0-73693cbd36bae
unix 2 [ ACC ] STREAM LISTENING 15702 /tmp/orbit-rci/linc-b43-0-73693cbdf135b
unix 2 [ ACC ] STREAM LISTENING 8907 /var/run/setroubleshoot/setroubleshoot_server
unix 2 [ ACC ] STREAM LISTENING 15734 /tmp/orbit-rci/linc-b52-0-20ceddbcccfc9
unix 2 [ ACC ] STREAM LISTENING 15917 /tmp/orbit-rci/linc-b66-0-35df726feada2
unix 2 [ ACC ] STREAM LISTENING 8874 /var/lib/mysql/mysql.sock
unix 2 [ ] DGRAM 8242 @/org/freedesktop/hal/udev_event
unix 2 [ ACC ] STREAM LISTENING 48108 /tmp/ssh-YcYey16192/agent.16192
unix 2 [ ACC ] STREAM LISTENING 29941 /tmp/ssh-GlYymO8310/agent.8310
unix 2 [ ACC ] STREAM LISTENING 9628 @/tmp/gdm-greeter-crQfWFHp
unix 22 [ ] DGRAM 7601 /dev/log
unix 2 [ ACC ] STREAM LISTENING 13044 @/tmp/dbus-jJVdWdSUqd
unix 2 [ ACC ] STREAM LISTENING 8218 @/var/run/hald/dbus-LsXE5XPvHM
unix 2 [ ACC ] STREAM LISTENING 13181 @/tmp/.ICE-unix/2738
unix 3 [ ] STREAM CONNECTED 53187 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 53186
unix 2 [ ] DGRAM 51722
unix 2 [ ] DGRAM 51120
unix 2 [ ] DGRAM 48184
unix 2 [ ] DGRAM 48084
unix 3 [ ] STREAM CONNECTED 47694
unix 3 [ ] STREAM CONNECTED 47693
unix 2 [ ] DGRAM 47675
unix 3 [ ] STREAM CONNECTED 45980 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 45979
unix 2 [ ] DGRAM 43649
unix 2 [ ] STREAM CONNECTED 43368 /tmp/keyring-8XGSLO/socket
unix 2 [ ] DGRAM 30032
unix 2 [ ] DGRAM 29914
unix 3 [ ] STREAM CONNECTED 28279 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 28278
unix 2 [ ] STREAM CONNECTED 28169
unix 3 [ ] STREAM CONNECTED 28168 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 28167
unix 2 [ ] STREAM CONNECTED 17264
unix 2 [ ] DGRAM 16894
unix 3 [ ] STREAM CONNECTED 15933
unix 3 [ ] STREAM CONNECTED 15932
unix 3 [ ] STREAM CONNECTED 15931 /tmp/.esd-504/socket
unix 3 [ ] STREAM CONNECTED 15930
unix 3 [ ] STREAM CONNECTED 15924 /tmp/orbit-rci/linc-b66-0-35df726feada2
unix 3 [ ] STREAM CONNECTED 15923
unix 3 [ ] STREAM CONNECTED 15922 /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix 3 [ ] STREAM CONNECTED 15921
unix 3 [ ] STREAM CONNECTED 15920 /tmp/orbit-rci/linc-b66-0-35df726feada2
unix 3 [ ] STREAM CONNECTED 15919
unix 3 [ ] STREAM CONNECTED 15916 /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix 3 [ ] STREAM CONNECTED 15915
unix 3 [ ] STREAM CONNECTED 15914 /tmp/.ICE-unix/2738
unix 3 [ ] STREAM CONNECTED 15913
unix 3 [ ] STREAM CONNECTED 15908 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 15907
unix 3 [ ] STREAM CONNECTED 15867 /tmp/.esd-504/socket
unix 3 [ ] STREAM CONNECTED 15866
unix 3 [ ] STREAM CONNECTED 15865 /tmp/orbit-rci/linc-b05-0-2ea2d3f7a45e4
unix 3 [ ] STREAM CONNECTED 15864
unix 3 [ ] STREAM CONNECTED 15863 /tmp/orbit-rci/linc-b52-0-20ceddbcccfc9
unix 3 [ ] STREAM CONNECTED 15862
unix 3 [ ] STREAM CONNECTED 15861 /tmp/orbit-rci/linc-b52-0-20ceddbcccfc9
unix 3 [ ] STREAM CONNECTED 15860
unix 3 [ ] STREAM CONNECTED 15859 /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix 3 [ ] STREAM CONNECTED 15858
unix 3 [ ] STREAM CONNECTED 15855 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 15854
unix 3 [ ] STREAM CONNECTED 15851 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 15850
unix 3 [ ] STREAM CONNECTED 15818 /tmp/.esd-504/socket
unix 3 [ ] STREAM CONNECTED 15817
unix 3 [ ] STREAM CONNECTED 15816 /tmp/orbit-rci/linc-b05-0-2ea2d3f7a45e4
unix 3 [ ] STREAM CONNECTED 15815
unix 3 [ ] STREAM CONNECTED 15814 /tmp/.esd-504/socket
unix 3 [ ] STREAM CONNECTED 15813
unix 3 [ ] STREAM CONNECTED 15781 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 15780
unix 3 [ ] STREAM CONNECTED 15778 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 15777
unix 3 [ ] STREAM CONNECTED 15779 /tmp/orbit-rci/linc-b05-0-2ea2d3f7a45e4
unix 3 [ ] STREAM CONNECTED 15776
unix 3 [ ] STREAM CONNECTED 15775 /tmp/.esd-504/socket
unix 3 [ ] STREAM CONNECTED 15774
unix 3 [ ] STREAM CONNECTED 15773 /tmp/orbit-rci/linc-b05-0-2ea2d3f7a45e4
unix 3 [ ] STREAM CONNECTED 15772
unix 3 [ ] STREAM CONNECTED 15771 /tmp/.esd-504/socket
unix 3 [ ] STREAM CONNECTED 15770
unix 3 [ ] STREAM CONNECTED 15755 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 15754
unix 3 [ ] STREAM CONNECTED 15753 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 15752
unix 3 [ ] STREAM CONNECTED 15737 /tmp/orbit-rci/linc-b52-0-20ceddbcccfc9
unix 3 [ ] STREAM CONNECTED 15736
unix 3 [ ] STREAM CONNECTED 15733 /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix 3 [ ] STREAM CONNECTED 15732
unix 3 [ ] STREAM CONNECTED 15731 /tmp/.ICE-unix/2738
unix 3 [ ] STREAM CONNECTED 15730
unix 3 [ ] STREAM CONNECTED 15724 /tmp/orbit-rci/linc-b05-0-2ea2d3f7a45e4
unix 3 [ ] STREAM CONNECTED 15723
unix 3 [ ] STREAM CONNECTED 15725 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 15722
unix 3 [ ] STREAM CONNECTED 15721 /tmp/orbit-rci/linc-b4e-0-73693cbd36bae
unix 3 [ ] STREAM CONNECTED 15720
unix 3 [ ] STREAM CONNECTED 15719 /tmp/orbit-rci/linc-b4c-0-73693cbd6ed7
unix 3 [ ] STREAM CONNECTED 15717
unix 3 [ ] STREAM CONNECTED 15718 /tmp/orbit-rci/linc-b4a-0-73693cbd6ab5
unix 3 [ ] STREAM CONNECTED 15716
unix 3 [ ] STREAM CONNECTED 15715 /tmp/orbit-rci/linc-b50-0-73693cbd64bf
unix 3 [ ] STREAM CONNECTED 15714
unix 3 [ ] STREAM CONNECTED 15713 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 15712
unix 3 [ ] STREAM CONNECTED 15707 /tmp/.esd-504/socket
unix 3 [ ] STREAM CONNECTED 15706
unix 3 [ ] STREAM CONNECTED 15705 /tmp/orbit-rci/linc-b43-0-73693cbdf135b
unix 3 [ ] STREAM CONNECTED 15704
unix 3 [ ] STREAM CONNECTED 15701 /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix 3 [ ] STREAM CONNECTED 15700
unix 3 [ ] STREAM CONNECTED 15698 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 15697
unix 3 [ ] STREAM CONNECTED 15696 /var/run/setroubleshoot/setroubleshoot_server
unix 3 [ ] STREAM CONNECTED 15695
unix 3 [ ] STREAM CONNECTED 15694 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 15693
unix 3 [ ] STREAM CONNECTED 15682 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 15681
unix 3 [ ] STREAM CONNECTED 15680 /tmp/orbit-rci/linc-b4e-0-73693cbd36bae
unix 3 [ ] STREAM CONNECTED 15679
unix 3 [ ] STREAM CONNECTED 15678 /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix 3 [ ] STREAM CONNECTED 15677
unix 3 [ ] STREAM CONNECTED 15676 /tmp/orbit-rci/linc-b4e-0-73693cbd36bae
unix 3 [ ] STREAM CONNECTED 15675
unix 3 [ ] STREAM CONNECTED 15672 /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix 3 [ ] STREAM CONNECTED 15671
unix 3 [ ] STREAM CONNECTED 15663 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 15662
unix 3 [ ] STREAM CONNECTED 15654 @/dbus-vfs-daemon/socket-2Ecvbxhb
unix 3 [ ] STREAM CONNECTED 15653
unix 3 [ ] STREAM CONNECTED 15655 @/dbus-vfs-daemon/socket-Jy4o6CFs
unix 3 [ ] STREAM CONNECTED 15652
unix 3 [ ] STREAM CONNECTED 15644 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 15643
unix 3 [ ] STREAM CONNECTED 15642 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 15641
unix 3 [ ] STREAM CONNECTED 15640 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 15639
unix 3 [ ] STREAM CONNECTED 15638 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 15637
unix 3 [ ] STREAM CONNECTED 15636 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 15635
unix 3 [ ] STREAM CONNECTED 15634 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 15633
unix 3 [ ] STREAM CONNECTED 15609 /tmp/orbit-rci/linc-b4c-0-73693cbd6ed7
unix 3 [ ] STREAM CONNECTED 15608
unix 3 [ ] STREAM CONNECTED 15607 /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix 3 [ ] STREAM CONNECTED 15606
unix 3 [ ] STREAM CONNECTED 15605 /tmp/orbit-rci/linc-b4a-0-73693cbd6ab5
unix 3 [ ] STREAM CONNECTED 15604
unix 3 [ ] STREAM CONNECTED 15603 /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix 3 [ ] STREAM CONNECTED 15602
unix 3 [ ] STREAM CONNECTED 15601 /tmp/orbit-rci/linc-b50-0-73693cbd64bf
unix 3 [ ] STREAM CONNECTED 15600
unix 3 [ ] STREAM CONNECTED 15599 /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix 3 [ ] STREAM CONNECTED 15598
unix 3 [ ] STREAM CONNECTED 15597 /tmp/orbit-rci/linc-b4c-0-73693cbd6ed7
unix 3 [ ] STREAM CONNECTED 15596
unix 3 [ ] STREAM CONNECTED 15593 /tmp/orbit-rci/linc-b4a-0-73693cbd6ab5
unix 3 [ ] STREAM CONNECTED 15592
unix 3 [ ] STREAM CONNECTED 15589 /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix 3 [ ] STREAM CONNECTED 15588
unix 3 [ ] STREAM CONNECTED 15587 /tmp/orbit-rci/linc-b50-0-73693cbd64bf
unix 3 [ ] STREAM CONNECTED 15586
unix 3 [ ] STREAM CONNECTED 15583 /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix 3 [ ] STREAM CONNECTED 15582
unix 3 [ ] STREAM CONNECTED 15579 /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix 3 [ ] STREAM CONNECTED 15578
unix 3 [ ] STREAM CONNECTED 15573 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 15572
unix 3 [ ] STREAM CONNECTED 15568 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 15567
unix 3 [ ] STREAM CONNECTED 15566 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 15565
unix 3 [ ] STREAM CONNECTED 15307 @/dbus-vfs-daemon/socket-EoSdv8tl
unix 3 [ ] STREAM CONNECTED 15305
unix 3 [ ] STREAM CONNECTED 15306 @/dbus-vfs-daemon/socket-wxiQqcnW
unix 3 [ ] STREAM CONNECTED 15304
unix 3 [ ] STREAM CONNECTED 15295 @/dbus-vfs-daemon/socket-MsxwgPfZ
unix 3 [ ] STREAM CONNECTED 15294
unix 3 [ ] STREAM CONNECTED 15296 @/dbus-vfs-daemon/socket-YTCTJRy2
unix 3 [ ] STREAM CONNECTED 15293
unix 3 [ ] STREAM CONNECTED 15290 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 15289
unix 3 [ ] STREAM CONNECTED 15288 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 15287
unix 2 [ ] DGRAM 15264
unix 3 [ ] STREAM CONNECTED 15263 /tmp/.esd-504/socket
unix 3 [ ] STREAM CONNECTED 15262
unix 3 [ ] STREAM CONNECTED 15261 /tmp/orbit-rci/linc-b05-0-2ea2d3f7a45e4
unix 3 [ ] STREAM CONNECTED 15260
unix 3 [ ] STREAM CONNECTED 15257 /tmp/.esd-504/socket
unix 3 [ ] STREAM CONNECTED 15256
unix 3 [ ] STREAM CONNECTED 15254 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 15253
unix 3 [ ] STREAM CONNECTED 15252 /tmp/orbit-rci/linc-b2e-0-7e6c12606a520
unix 3 [ ] STREAM CONNECTED 15251
unix 3 [ ] STREAM CONNECTED 15248 /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix 3 [ ] STREAM CONNECTED 15247
unix 3 [ ] STREAM CONNECTED 15230 /tmp/orbit-rci/linc-b05-0-2ea2d3f7a45e4
unix 3 [ ] STREAM CONNECTED 15229
unix 3 [ ] STREAM CONNECTED 15226 /tmp/orbit-rci/linc-b2b-0-5cc9ebe33f113
unix 3 [ ] STREAM CONNECTED 15227 @/dbus-vfs-daemon/socket-vyFkI0KY
unix 3 [ ] STREAM CONNECTED 15225
unix 3 [ ] STREAM CONNECTED 15224
unix 3 [ ] STREAM CONNECTED 15228 @/dbus-vfs-daemon/socket-TohDlvGS
unix 3 [ ] STREAM CONNECTED 15223
unix 3 [ ] STREAM CONNECTED 15217 @/dbus-vfs-daemon/socket-SuaXxO7U
unix 3 [ ] STREAM CONNECTED 15216
unix 3 [ ] STREAM CONNECTED 15218 @/dbus-vfs-daemon/socket-Dg6oj7RH
unix 3 [ ] STREAM CONNECTED 15215
unix 3 [ ] STREAM CONNECTED 15204 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 15201
unix 3 [ ] STREAM CONNECTED 15182 /tmp/.esd-504/socket
unix 3 [ ] STREAM CONNECTED 15181
unix 3 [ ] STREAM CONNECTED 15180 /tmp/orbit-rci/linc-b2c-0-5cc9ebe34d01c
unix 3 [ ] STREAM CONNECTED 15179
unix 3 [ ] STREAM CONNECTED 15173 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 15172
unix 3 [ ] STREAM CONNECTED 15170 /tmp/orbit-rci/linc-b2c-0-5cc9ebe34d01c
unix 3 [ ] STREAM CONNECTED 15169
unix 3 [ ] STREAM CONNECTED 15168 /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix 3 [ ] STREAM CONNECTED 15167
unix 3 [ ] STREAM CONNECTED 15166 /tmp/orbit-rci/linc-b2c-0-5cc9ebe34d01c
unix 3 [ ] STREAM CONNECTED 15165
unix 3 [ ] STREAM CONNECTED 15162 /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix 3 [ ] STREAM CONNECTED 15161
unix 3 [ ] STREAM CONNECTED 15141 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 15140
unix 3 [ ] STREAM CONNECTED 15137 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 15136
unix 3 [ ] STREAM CONNECTED 15135 /tmp/orbit-rci/linc-b2b-0-5cc9ebe33f113
unix 3 [ ] STREAM CONNECTED 15134
unix 3 [ ] STREAM CONNECTED 15133 /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix 3 [ ] STREAM CONNECTED 15132
unix 3 [ ] STREAM CONNECTED 15131 /tmp/orbit-rci/linc-b2b-0-5cc9ebe33f113
unix 3 [ ] STREAM CONNECTED 15130
unix 3 [ ] STREAM CONNECTED 15114 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 15112
unix 3 [ ] STREAM CONNECTED 15113 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 15111
unix 3 [ ] STREAM CONNECTED 15104 /tmp/.ICE-unix/2738
unix 3 [ ] STREAM CONNECTED 15103
unix 3 [ ] STREAM CONNECTED 15101 /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix 3 [ ] STREAM CONNECTED 15100
unix 3 [ ] STREAM CONNECTED 15099 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 15096
unix 3 [ ] STREAM CONNECTED 15092 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 15091
unix 3 [ ] STREAM CONNECTED 15089 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 15088
unix 3 [ ] STREAM CONNECTED 15083 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 15082
unix 3 [ ] STREAM CONNECTED 15080 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 15079
unix 3 [ ] STREAM CONNECTED 15078 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 15077
unix 2 [ ] DGRAM 15076
unix 3 [ ] STREAM CONNECTED 15075 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 15074
unix 3 [ ] STREAM CONNECTED 15073 /tmp/orbit-rci/linc-b12-0-2ea2d3f6231fb
unix 3 [ ] STREAM CONNECTED 15072
unix 3 [ ] STREAM CONNECTED 15069 /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix 3 [ ] STREAM CONNECTED 15067
unix 3 [ ] STREAM CONNECTED 15066 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 15065
unix 3 [ ] STREAM CONNECTED 14907 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 14906
unix 3 [ ] STREAM CONNECTED 14828 /tmp/.esd-504/socket
unix 3 [ ] STREAM CONNECTED 14825
unix 3 [ ] STREAM CONNECTED 14815 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 14814
unix 3 [ ] STREAM CONNECTED 14800 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 14797
unix 3 [ ] STREAM CONNECTED 14795 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 14794
unix 3 [ ] STREAM CONNECTED 14793 /tmp/orbit-rci/linc-b13-0-7550bfade1198
unix 3 [ ] STREAM CONNECTED 14792
unix 3 [ ] STREAM CONNECTED 14760 /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix 3 [ ] STREAM CONNECTED 14756
unix 3 [ ] STREAM CONNECTED 14753 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 14752
unix 3 [ ] STREAM CONNECTED 14748 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 14747
unix 3 [ ] STREAM CONNECTED 14746 /tmp/orbit-rci/linc-b07-0-2ea2d3f7bd3df
unix 3 [ ] STREAM CONNECTED 14745
unix 3 [ ] STREAM CONNECTED 14744 /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix 3 [ ] STREAM CONNECTED 14743
unix 3 [ ] STREAM CONNECTED 15031 /tmp/.ICE-unix/2738
unix 3 [ ] STREAM CONNECTED 14742
unix 3 [ ] STREAM CONNECTED 14700 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 14699
unix 3 [ ] STREAM CONNECTED 14698 /tmp/orbit-rci/linc-b0d-0-374d9efed4dcf
unix 3 [ ] STREAM CONNECTED 14697
unix 3 [ ] STREAM CONNECTED 14694 /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix 3 [ ] STREAM CONNECTED 14693
unix 3 [ ] STREAM CONNECTED 14689 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 14688
unix 3 [ ] STREAM CONNECTED 14687 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 14686
unix 3 [ ] STREAM CONNECTED 14683 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 14682
unix 3 [ ] STREAM CONNECTED 14616 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 14614
unix 3 [ ] STREAM CONNECTED 14609 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 14608
unix 3 [ ] STREAM CONNECTED 14444 /tmp/orbit-rci/linc-b05-0-2ea2d3f7a45e4
unix 3 [ ] STREAM CONNECTED 14443
unix 3 [ ] STREAM CONNECTED 14412 /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix 3 [ ] STREAM CONNECTED 14410
unix 3 [ ] STREAM CONNECTED 14411 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 14408
unix 3 [ ] STREAM CONNECTED 14404 /tmp/orbit-rci/linc-b07-0-2ea2d3f7bd3df
unix 3 [ ] STREAM CONNECTED 14403
unix 3 [ ] STREAM CONNECTED 14400 /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix 3 [ ] STREAM CONNECTED 14399
unix 3 [ ] STREAM CONNECTED 14368 /tmp/.ICE-unix/2738
unix 3 [ ] STREAM CONNECTED 14367
unix 3 [ ] STREAM CONNECTED 14362 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 14361
unix 3 [ ] STREAM CONNECTED 14358 /tmp/.ICE-unix/2738
unix 3 [ ] STREAM CONNECTED 14357
unix 3 [ ] STREAM CONNECTED 14319 /tmp/orbit-rci/linc-b03-0-646c1b0a4955
unix 3 [ ] STREAM CONNECTED 14318
unix 3 [ ] STREAM CONNECTED 14315 /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix 3 [ ] STREAM CONNECTED 14314
unix 3 [ ] STREAM CONNECTED 14313 /tmp/orbit-rci/linc-b05-0-2ea2d3f7a45e4
unix 3 [ ] STREAM CONNECTED 14312
unix 3 [ ] STREAM CONNECTED 14309 /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix 3 [ ] STREAM CONNECTED 14308
unix 3 [ ] STREAM CONNECTED 14304 /tmp/.ICE-unix/2738
unix 3 [ ] STREAM CONNECTED 14303
unix 3 [ ] STREAM CONNECTED 14299 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 14297
unix 3 [ ] STREAM CONNECTED 14296 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 14295
unix 3 [ ] STREAM CONNECTED 14284 /tmp/.esd-504/socket
unix 3 [ ] STREAM CONNECTED 14282
unix 3 [ ] STREAM CONNECTED 14198 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 14197
unix 3 [ ] STREAM CONNECTED 14196 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 14195
unix 3 [ ] STREAM CONNECTED 14194 /tmp/orbit-rci/linc-af8-0-2a9c73557117d
unix 3 [ ] STREAM CONNECTED 14193
unix 3 [ ] STREAM CONNECTED 14190 /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix 3 [ ] STREAM CONNECTED 14189
unix 3 [ ] STREAM CONNECTED 14185 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 14184
unix 3 [ ] STREAM CONNECTED 13959 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 13958
unix 3 [ ] STREAM CONNECTED 13957 /tmp/orbit-rci/linc-af0-0-291584f2dff14
unix 3 [ ] STREAM CONNECTED 13956
unix 3 [ ] STREAM CONNECTED 13953 /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix 3 [ ] STREAM CONNECTED 13952
unix 3 [ ] STREAM CONNECTED 13966 /tmp/.esd-504/socket
unix 3 [ ] STREAM CONNECTED 13925
unix 3 [ ] STREAM CONNECTED 13886 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 13881
unix 3 [ ] STREAM CONNECTED 13385 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 13384
unix 3 [ ] STREAM CONNECTED 13211 /tmp/orbit-rci/linc-aeb-0-38fb5be1c67e3
unix 3 [ ] STREAM CONNECTED 13210
unix 3 [ ] STREAM CONNECTED 13207 /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix 3 [ ] STREAM CONNECTED 13206
unix 3 [ ] STREAM CONNECTED 13202 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 13201
unix 3 [ ] STREAM CONNECTED 13199 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 13198
unix 3 [ ] STREAM CONNECTED 13190 @/tmp/dbus-jJVdWdSUqd
unix 3 [ ] STREAM CONNECTED 13189
unix 3 [ ] STREAM CONNECTED 13180 /tmp/orbit-rci/linc-ab2-0-6313415bafe9f
unix 3 [ ] STREAM CONNECTED 13179
unix 3 [ ] STREAM CONNECTED 13176 /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix 3 [ ] STREAM CONNECTED 13175
unix 3 [ ] STREAM CONNECTED 13148 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 13147
unix 3 [ ] STREAM CONNECTED 13057 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 13056
unix 3 [ ] STREAM CONNECTED 13054
unix 3 [ ] STREAM CONNECTED 13053
unix 4 [ ] STREAM CONNECTED 13029 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 13028
unix 2 [ ] DGRAM 13017
unix 3 [ ] STREAM CONNECTED 13014 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 13013
unix 2 [ ] DGRAM 12986
unix 3 [ ] STREAM CONNECTED 12892 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 12891
unix 3 [ ] STREAM CONNECTED 10063 @/tmp/gdm-session-ZfztANUC
unix 3 [ ] STREAM CONNECTED 10062
unix 3 [ ] STREAM CONNECTED 9681 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 9680
unix 3 [ ] STREAM CONNECTED 9677 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 9676
unix 5 [ ] STREAM CONNECTED 9650 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 9649
unix 5 [ ] STREAM CONNECTED 9586 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 9585
unix 3 [ ] STREAM CONNECTED 9582 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 9581
unix 3 [ ] STREAM CONNECTED 9502 /var/run/acpid.socket
unix 3 [ ] STREAM CONNECTED 9501
unix 3 [ ] STREAM CONNECTED 9481 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 9480
unix 3 [ ] STREAM CONNECTED 9458 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 9457
unix 3 [ ] STREAM CONNECTED 9075 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 9074
unix 3 [ ] STREAM CONNECTED 9069
unix 3 [ ] STREAM CONNECTED 9068
unix 2 [ ] DGRAM 9066
unix 3 [ ] STREAM CONNECTED 8972 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 8971
unix 2 [ ] DGRAM 8915
unix 3 [ ] STREAM CONNECTED 8911 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 8910
unix 3 [ ] STREAM CONNECTED 8906 /var/run/audispd_events
unix 3 [ ] STREAM CONNECTED 8905
unix 2 [ ] DGRAM 8728
unix 2 [ ] DGRAM 8725
unix 3 [ ] STREAM CONNECTED 8724 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 8723
unix 3 [ ] STREAM CONNECTED 8720 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 8719
unix 3 [ ] STREAM CONNECTED 8636 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 8635
unix 2 [ ] DGRAM 8632
unix 3 [ ] STREAM CONNECTED 8422 @/var/run/hald/dbus-XPPhnxy7GD
unix 3 [ ] STREAM CONNECTED 8421
unix 3 [ ] STREAM CONNECTED 8418 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 8417
unix 3 [ ] STREAM CONNECTED 8394 /var/run/acpid.socket
unix 3 [ ] STREAM CONNECTED 8393
unix 3 [ ] STREAM CONNECTED 8388 @/var/run/hald/dbus-XPPhnxy7GD
unix 3 [ ] STREAM CONNECTED 8387
unix 3 [ ] STREAM CONNECTED 8346 @/var/run/hald/dbus-XPPhnxy7GD
unix 3 [ ] STREAM CONNECTED 8325
unix 3 [ ] STREAM CONNECTED 8237 @/var/run/hald/dbus-LsXE5XPvHM
unix 3 [ ] STREAM CONNECTED 8236
unix 3 [ ] STREAM CONNECTED 8215 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 8214
unix 3 [ ] STREAM CONNECTED 8199 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 8198
unix 2 [ ] DGRAM 8174
unix 3 [ ] STREAM CONNECTED 8068
unix 3 [ ] STREAM CONNECTED 8067
unix 3 [ ] STREAM CONNECTED 8012
unix 3 [ ] STREAM CONNECTED 8011
unix 2 [ ] DGRAM 7703
unix 3 [ ] STREAM CONNECTED 7537
unix 3 [ ] STREAM CONNECTED 7536
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
192.168.254.0 0.0.0.0 255.255.255.0 U 0 0 0 eth2
134.79.32.0 0.0.0.0 255.255.252.0 U 0 0 0 eth0
169.254.0.0 0.0.0.0 255.255.0.0 U 0 0 0 eth2
0.0.0.0 134.79.35.1 0.0.0.0 UG 0 0 0 eth0
- Re: Channel Access not connecting Maren Purves
- RE: Channel Access not connecting Mark Rivers
- Re: Channel Access not connecting Claude Saunders
RE: EPICS support for OMRON PLC SYSMAC CJIM CPU12-ETN Ethernet communications? CryoCon RS-232? Jay Steele
<2011>
Announce: seq-2.0.14 Benjamin Franksen
<2011>
