g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Subject: Modbus R2-2 available
To: <tech-talk@aps.anl.gov>
Date: Thu, 17 Mar 2011 17:50:11 -0500
Release 2-2 of the EPICS "modbus" module is now available.  This is from
the release notes:
- R2-0 introduced a 20 ms delay before each Modbus write. This was not
correct, delays should only be needed for serial RTU. The Modicon Modbus
Protocol Reference Guide says this must be at least 3.5 character times,
e.g. about 3.5ms at 9600 baud, for Serial RTU. An additional
writeDelayMsec parameter was added to modbusInterposeConfig. It is the
final parameter, so if it is not specified the default value is zero,
which is appropriate when not using Serial RTU. In the startup script
lines like the following:
    modbusInterposeConfig("Koyo1",0,5000)
should be changed to:
    modbusInterposeConfig("Koyo1",0,5000,0)
for no delay, or to:
    modbusInterposeConfig("Koyo1",0,5000,20)
for a 20 ms delay.
The release notes are here:
http://cars.uchicago.edu/software/epics/modbusReleaseNotes.html
The documentation is here:
http://cars.uchicago.edu/software/epics/modbusDoc.html
The tar file is here:
http://cars.uchicago.edu/software/pub/modbusR2-2.tgz
Please let me know of any problems or questions.
Cheers,
Prev: Python with EPICS [was Re: epicsqt first try] Angus Gratton
Next: MEDM Andy Foster
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Prev: RE: epicsqt first try Andrew Rhyder
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
