g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Subject: Re: EPICS Config for 2 Ethernet Adapters
To: graham.cox@stfc.ac.uk
Cc: tech-talk@aps.anl.gov
Date: Tue, 15 Feb 2011 10:52:37 -0500
Look in the CA Reference Manual for your release of EPICS.  I think
you need to specify EPICS_CAS_INTF_ADDR_LIST .
-ps
On Tue, Feb 15, 2011 at 10:33,  <graham.cox@stfc.ac.uk> wrote:
> Hi,
> I have a Linux x86 IOC which takes data from a legacy control system and converts it to EPICS data.  Where both controls systems co-exist on one network the IOC works fine running on a single ethernet adapter machine.
> I now need to take the legacy data from one network and make available on another network via EPICS.  I have a Linux PC with 2 ethernet adapters, eth0 the legacy control system, eth1 the EPICS control system.  The IOC runs on this machine except I cannot see the EPICS PVs via other machines on the eth1 network.
> I'm guessing that the EPICS IOC is binding to eth0 by default and expecting to serve data to this network?
> How do I configure EPICS to bind to eth1 rather than to eth0, is this possible?
> Thanks,
> Graham--
> Scanned by iCritical.
Re: EPICS Config for 2 Ethernet Adapters Andrew Johnson
EPICS Config for 2 Ethernet Adapters graham.cox
Prev: Re: no envPaths in application of base 3.14.11 Andrew Johnson
Next: Re: EPICS Config for 2 Ethernet Adapters Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Prev: EPICS Config for 2 Ethernet Adapters graham.cox
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
