Is anyone using any Atomtex radiation monitors? These devices have a modbus RTU implementation but the CRC bytes are reversed!! Works o/k with their own windows applications as these also swap the CRC bytes. Trying to convince Atomtex to fix this and looking to see if there is any other facilities that could support our case. Regards  Bryce Karnaghan | Principal Controls Engineer | Australian Synchrotron p: (03) 8540 4135 | f: (03) 8540 4200 | m: 0423 844 592 bryce.karnaghan@synchrotron.org.au | www.synchrotron.org.au 800 Blackburn Road, Clayton, Victoria 3168
This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you. |
Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Ernest L. Williams Jr.
Error vxi11 with Lecroy 760Zi DENIS Jean-françois
<2011>
Problem building EPICSQt ASgui Morgan Bradford
<2011>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
EPICSv4
IRMIS
Talk
Bugs
Documents
Links
Licensing
