Hi Ernest,
> CAS: no space in pool for a new client (below max block thresh)
This happens when osiSufficentSpaceInPool return FALSE. The CA server tries
its best to not use the very last bit of memory (of RAM), and it calls
osiSufficentSpaceInPool to find out when it's getting too close to the end.
If its vxWorks or RTEMS it may be that your IOC is in a RAM limited
situation, or its system pool is severely fragmented. Also, the RTEMS
implementation of osiSufficentSpaceInPool is more recent than the vxWorks
version (which is probably unmodified since the early 90s).
On other OS we currently assume that running out of RAM isn't much of an
issue because of page files, and or no one has taken time to implement a
better approach, so osiSufficentSpaceInPool always returns TRUE.
On RTEMS:
* osiSufficentSpaceInPool ()
epicsShareFunc int epicsShareAPI osiSufficentSpaceInPool ( size_t
contiguousBlockSize )
rtems_malloc_statistics_t s;
unsigned long n;
malloc_get_statistics(&s);
n = s.space_available - (unsigned long)(s.lifetime_allocated -
s.lifetime_freed);
return (n > (50000 + contiguousBlockSize));
On vxWorks:
epicsThreadOnce ( &osdMaxBlockOnceler, osdSufficentSpaceInPoolInit, 0 );
if ( UINT_MAX - 100000u >= contiguousBlockSize ) {
return ( osdMaxBlockSize > 100000 + contiguousBlockSize );
else {
return 0;
Jeff
______________________________________________________
Jeffrey O. Hill Email johill@lanl.gov
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: Ernest L. Williams Jr. [mailto:ernesto@slac.stanford.edu]
> Sent: Friday, February 11, 2011 9:39 AM
> To: Jeff Hill; Andrew Johnson
> Cc: Ernest L. Williams Jr.; Eric Bjorklund
> Subject: CAS: no space in pool for a new client (below max block thresh)
> in EPICS R3.14.12
> Hi Jeff,
> What vxWorks resource must I increase to address this message after
> booting my Petium4 VME IOC running EPICS R3.14.12?
> I get the following: CAS: no space in pool for a new client (below max
> block thresh)
> iocInit
> iocInit: Reached initHookAtIocBuild
> Starting iocInit
> iocInit: Reached initHookAtBeginning
> ## EPICS R3.14.12-SLAC_1 $Date: 2010/11/27 17:57:27 $
> ## EPICS Base built Feb 11 2011
> iocInit: Reached initHookAfterCallbackInit
> iocInit: Reached initHookAfterCaLinkInit
> iocInit: Reached initHookAfterInitDrvSup
> iocInit: Reached initHookAfterInitRecSup
> iocInit: Reached initHookAfterInitDevSup
> iocInit: Reached initHookAfterInitDatabase
> iocInit: Reached initHookAfterFinishDevSup
> iocInit: Reached initHookAfterScanInit
> iocInit: Reached initHookAfterInitialProcess
- Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Ernest L. Williams Jr.
RE: USB4000 David Beauregard
<2011>
Re: soft ioc runs into fatal exception (base-3.14.12) Andrew Johnson
<2011>
