g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013
Subject: RE: About PCAS Access Control
To: 'åçä' <zhangyl@ihep.ac.cn>, "'tech-talk'" <tech-talk@aps.anl.gov>
Date: Mon, 20 Dec 2010 11:03:01 -0700
Sorry about the delay responding , I took some âvacationâ time to set some tile in the basement of my house.
à Here is my question. I want to add  access control to my PCAS,
à but I do not  know what the pUserName and pHostName in the
à following function refer to clearly.
à virtual casChannel *createChannel ( const casCtx &ctx,const
à char * const pUserName,const char * const pHostName);
à
In the createChannel virtual member function the pUserName argument is a constant nill terminated string which is the user name of the user account the ca clientâs application is running under. In the createChannel virtual member function the pHostName argument is a constant nill terminated string which is the name (typically the dns name) of the host the ca clientâs application is running on.
à In "Channel Access Protable Server API Tutorial" it said
à that points to a string representing the user's name and  pHostName
à points to a string representing the server tool's host.
There might be a documentation issue here. It should say that it is the host name (typically the dns name) of the _clientâs_, and not the serverâs, host. I created bug entry 692664 at the epics launchpad site.
à
à For example, I have
à two EDM clients application run on the same linux PC, does the user's name
à refer to the PC name or something else.
The user name of the user account the client application runs on.
à William Lu wrote:
à Channel access security is better achieved by usnig the
à EPICS access security API. If you follow that path, at
à some point in your pcas code you will call
à asAddClient(&client, member, asl, pUserName, pHostName),
à to which you pass the pUserName and pHostName, as illustrated bellow:
Yes, this is the typical approach - which causes access security configuration of your service to be similar to, for example, an IOC or the ca gateway.
Jeff
______________________________________________________
Jeffrey O. Hill           Email    ÂÂÂ
johill@lanl.gov
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of ???
Sent: Monday, December 13, 2010 7:54 PM
To: tech-talk
Subject: About PCAS Access Control
Hi all,
Here is my question. I want to add  access control to my PCAS, but I do not  know what the pUserName and pHostName in the following function refer to clearly.
virtual casChannel *createChannel ( const casCtx &ctx,const char * const pUserName,const char * const pHostName);
In "Channel Access Protable Server API Tutorial" it said that points to a string representing the user's name and  pHostName points to a string representing the server tool's host. For example, I have two EDM clients application run on the same linux PC, does the user's name refer to the PC name or something else.
I have implemented the createChannel function and  writeAccess function like this:
casChannel *exPV::createChannel ( const casCtx &ctx,
        const char * const  /*pUserName*/,
        const char * const  /*pHostName*/)
    return new exChannel ( ctx,"zhangyul","Administrator");
bool exChannel::writeAccess () const
      if (strcmp(User.string(), "zhangyul") == 0)
return aitFalse;
      else
return aitTrue;
However, I found that any client could not write the PCAS's PV, I think my understanding is totally wrong about user's name and the host name!!
Thank you!
Zhang Yuliang
About PCAS Access Control 张玉亮
Prev: epics under NET OS Yuriy Gorbunov
Next: RE: Problem: Build EPICS 3.14.12 on windows 7 using Visual C++ 2010 Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013
Prev: Re: About PCAS Access Control William Lu
Next: Controls Group vacancies Diamond Light Source mark.heron
ANJ, 20 Dec 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
