Hi Pierrick,
INAA, INBB, etc. are input links, you will want to set your strings
("Dry", etc.)
in the corresponding .AA, .BB ... fields. SVAL will contain the string
result of
the calculation, so you don't want to try to force a PV name in there. The
stringout's PV name should go into the scalcout's .OUT field, in which case
you will not need to forward link to the stringout record.
hth,
Kurt
Pierrick Hanlet wrote:
Hi Kurt,
I'm still having trouble with my db. This is actually what I have. The problem
appears to be in the definition of INAA, INBB, INCC. When I do a caget or
camonitor of MICE-ENV-AC-LEAK-04:calStatus.AA, I find that I have no value
stored there. I do see the fields INAA, etc, defined in the dbd file.
The calculation works correctly, as I get the expected 1,0,-1 if I use the
uncommented CALC line.
record(scalcout,"MICE-ENV-AC-LEAK-04:calStatus") {
field(DESC,"Water leak status determination")
field(SCAN,"10 second")
field(INPA,"MICE-ENV-SECPRB-01:WaterLeakStatus4")
field(INPB,"MICE-ENV-SECPRB-01:WaterLeakValue4")
field(INAA,"Dry")
field(INBB,"Leak detected")
field(INCC,"Error")
# field(CALC,"(A=2||A=4)&&B=0?AA:(A=2||A=4)&&B=BB?1:CC")
field(CALC,"(A=2||A=4)&&B=0?0:(A=2||A=4)&&B=1?1:-1")
field(SVAL,"MICE-ENV-AC-LEAK-04:Status")
field(FLNK,"MICE-ENV-AC-LEAK-04:Status.PROC")
#record(stringout,"MICE-ENV-AC-LEAK-04:Status") {
record(ao,"MICE-ENV-AC-LEAK-04:Status") {
field(DESC,"AC unit water drip status")
field(SCAN,"Passive")
field(FLNK,"MICE-ENV-AC-LEAK-01:foStatus.PROC")
Any ideas? Thanks,
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
hanlet@fnal.gov
(630)840-5555/8871/6039 office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
----- Original Message -----
Date: Wednesday, August 18, 2010 9:26 am
Subject: Re: sCalcout
To: Pierrick Hanlet <hanlet@fnal.gov>
Cc: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Hi Pierrick,
I don't see a problem with your conditional expression. Note that in
the second example, your desired output will appear in the record's ".SVAL'
field.
Kurt
Hello,
I don't understand the online documentation regarding the string
output of sCalcout. I want to write
a string based on the results of a calculation. Ex:
record(scalcout,"myrecord")
field(INPA,"xxx")
field(INPB,"yyy")
field(CALC,"(A=1&&B=0?1:A=0&&B=1?0:-1")
What I would really like is
field(INPA,"xxx")
field(INPB,"yyy")
field(INAA,"Good")
field(INBB,"Bad")
field(INCC,"Ugly")
field(CALC,"(A=1&&B=0?AA:A=0&&B=1?BB:CC")
What is the correct syntax for affecting this?
Thanks in advance,
Pierrick
Pierrick Hanlet
Batavia, IL 60510
hanlet@fnal.gov
- sCalcout Pierrick Hanlet
- Re: sCalcout Kurt Goetze
- Re: sCalcout - again Pierrick Hanlet
Re: sCalcout - again J. Lewis Muir
<2010>
<2010>
