g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013
Subject: MEDM/Motif problem
To: tech-talk@aps.anl.gov
Date: Fri, 20 Aug 2010 11:00:10 -0700
Hi everyone,
I'm trying to build a simple GUI using MEDM but I'm running into the problem that I can't save any changes to .adl files, either that I create or those created by others. Specifically, when I launch MEDM and create a new display, MEDM crashes when I attempt to Save, Save All or Save As... using either the menu or Ctrl + S on the key board. I am given the error message:
dyld: lazy symbol binding failed: Symbol not found: _XftDrawCreate
  Referenced from: /usr/X11R6/lib/libXm.4.dylib
  Expected in: flat namespace
dyld: Symbol not found: _XftDrawCreate
[1]+  Trace/BPT trap          medm
I have successfully compiled openmotif-2.3.0 and MEDM3_1_4 from source on OSX 10.6.4 . Based on the error message I would guess that XftDrawCreate is a deprecated function call that doesn't exist in openmotif-2.3.0 . Are there any MEDM/motif experts that can suggest a fix? Thanks very much.
Andrew
Re: MEDM/Motif problem Eric Norum
Prev: Re: msi again Andrew Johnson
Next: Re: MEDM/Motif problem Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013
Prev: Re: msi again Benjamin Franksen
ANJ, 08 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
