Hi all,
Since upgrading the EPICS base version of the caGateways to 3.14.11, the
gateway dies from time to time for no obvious reason. It does not write
any log message when it dies (as it would do in a clean shutdown, in
case of a signal or when any strange CA event happens.) It also does not
write anything to stderr. I cannot remember that I have seen this type
of fault with 3.13.8.
Any idea?
Dirk
- Re: CA gateway dies without error message Andrew Johnson
- RE: CA gateway dies without error message Jeff Hill
Re: Asyn and I/O intr scanning Hinko Kocevar
RE: hex stream processing with StreamDevice? Mark Rivers
<2010>
synApps/vme-2-7/vmeApp/src for RTEMS (using EPICS libCom/osi Library) required Heinz Junkes
<2010>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
EPICSv4
IRMIS
Talk
Bugs
Documents
Links
Licensing
