Hi everyone,
I'm new to EPICS and I'm having problems with a new driver & device
support package I'm writing.
It seems that I can't get the link name to parse from my test database
file. The device support is registered successfully, and when it hits my
init_record function the 'type' is set correctly (VME_IO). However the
card and signal numbers aren't parsing (they are always 0 and 0,
respectively.)
Here is the db entry:
record(bo, "testrelay")
field(DESC, "Test relay")
field(OUT, "#C1 S1")
field(DTYP, "xvme260")
field(ZNAM, "open")
field(ONAM, "closed")
field(SCAN,"Passive")
I've tried various values in the OUT field including "#C1 S1 @" "#C1"
and "VME_IO #C1 S1", plus some others.
The .dbd file:
# XVME260 support
driver(xvme260)
variable(xvme260Debug, int)
registrar(xvme260Register)
device(bo, VME_IO, xvme260Bo, "xvme260")
Here's the dbpr from the IOC (excuse email reformatting):
> dbpr testrelay, 1
ASG: BKPT: 00 COSV: NO_ALARM
DESC: Test relay
DISA: 0 DISP: 0 DISS: NO_ALARM
DISV: 1
DOL:CONSTANT DTYP: xvme260 EVNT: 0
FLNK:CONSTANT 0
HIGH: 0 MASK: 0 NAME: testrelay
OMSL: supervisory
ONAM: closed OSV: NO_ALARM OUT:VME_IO #C0 S0 @
PACT: 0
PHAS: 0 PINI: NO PRIO: LOW
PUTF: 0
RBV: 0 RPRO: 0 RVAL: 0
SCAN: Passive
SDIS:CONSTANT SEVR: INVALID SIML:CONSTANT
SIMM: NO
SIOL:CONSTANT STAT: UDF TPRO: 0
TSE: 0
TSEL:CONSTANT UDF: 1 VAL: 0
ZNAM: open
ZSV: NO_ALARM
As you can see, it's picked up everything from the .db correctly apart
from OUT.
I've also verified my record_init is being called, and it's definitely
erroring due to the invalid card number in OUT. The 'type' field is set
right in OUT, but then all the fields in the 'vmeio' struct are zero.
I'm sure I'm doing something obviously wrong for a newbie, please can
anyone point me at what I should be investigating?
Thanks in advance.
Cheers,
Angus
- Re: Newbie IOC driver/device support problem Burkhard Kolb
Driver for Agilent 34970A Andrew Wagner
<2010>
<2010>
