g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013
Subject: Re: How to compile the sysVmeMapShow() function to the MVME5500 BSP?
To: éè <yanfen@sinap.ac.cn>
Cc: tech-talk@aps.anl.gov
Date: Mon, 26 Apr 2010 10:42:04 -0500
On Sunday 25 April 2010 02:18:58 éè wrote:
> I'm from SSRF. After I use sysVmeMapShow() function to the MVME5500 BSP, it
> display as follow:
>    -> sysVmeMapShow
>    VMEbus access from CPU:
>    CPU: 0xE7F00000 - 0xE7F3FFFF  =>  A32: 0xE7F00000 - 0xE7F3FFFF
>         0xEFF00000 - 0xF0EFFFFF  =>  A24:   0x000000 -   0xFFFFFF
>         0xF0F00000 - 0xF0F0FFFF  =>  A16:     0x0000 -     0xFFFF
>    CPU access from VMEbus:
>         A32:             -             =>            -
>         A24:    0x000000 - 0xFFFFFFFF  => 0x0F0F0000 - 0x0F0EFFFF
>    value = 0 = 0x0
> Do you think the display is OKïThe A32 address is available? Would you mind
> give me some suggestion about the blank of A32 address in "CPU access from
> VMEbus"?
I should first explain how to read the two parts of the command output:
The first section, "VMEbus access from CPU" shows you the VME Master windows
from the Universe-2 bus bridge, i.e. which VME address ranges the programs
running on the MVME5500 CPU have direct access to.  If a program does a read
from address 0xf0f08000 it will be converted into a VMEbus read from address
0x8000 in the A16 address space, and similarly for the other addresses in that
range.  The addresses in this section are the ones that you normally need to
know about when thinking about VME slave boards.
The second section "CPU access from VMEbus" probably should really be titled
"RAM access from VMEbus".  It shows you the VME Slave windows from the
Universe-2 bus bridge, i.e. at which VME addresses (if any) the RAM on the
MVME5500 can be accessed by any other VME Bus Master boards in your system.  A
VME Master might be a board with a built-in DMA controller but no local RAM,
or it might even be a CPU board such as another MVME5500.  These are less
common, but they do exist and get used with EPICS.  You should only worry
about the addresses in this section if you know you have a board that can act
as a VME Bus Master.
Now, in your case above the addresses in the second section do not look
correct to me, but this could be for a number of reasons related to which
Universe-2 slave windows are programmed by the BSP for which purposes.  I
suspect that the sysVmeMapShow() code was programmed specifically for the
board it came from, and if you didn't adjust it correctly when you added it to
your BSP then if may be showing the wrong information.
If you don't have any other VME Bus Master boards in the system you probably
don't need to worry about this and I would recommend deleting that section of
code from the sysVmeMapShow() routine so as not to cause confusion in the
future.
If you /do/ have any boards with a VME Bus Master interface that you plan to
use, you probably will need your to open a VME Slave window on your Universe-2
bridge to give the board(s) access to an area of the CPU's memory for them to
do I/O into.  In that case you should fix the sysVmeMapShow() code by looking
at how the mv5500 BSP sets up the chip's window registers and making sure that
you display the right ones.
You will have to read the MVME5500 User Guide and Programmer's Reference
Manual from the board manufacturer (downloadable from their website usually)
and the Universe-2 Reference Manual from the Tundra website and learn how CPU
addresses get mapped to the PCI bus and then how the Universe-2 registers let
you set up mappings between the PCI bus and VME bus and back.  This could take
some time to understand, and unfortunately every MVME CPU board and Wind River
BSP is different.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
How to compile the sysVmeMapShow() function to the MVME5500 BSP? 周永年
Re: How to compile the sysVmeMapShow() function to the MVME5500 BSP? Andrew Johnson
Re: How to compile the sysVmeMapShow() function to the MVME5500 BSP? éè
Prev: Re: How to compile the sysVmeMapShow() function to the MVME5500 BSP? éè
Next: Interests in EPICS c# Library zplayzplay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013
Next: epicsThreadOnceOsd epicsMutexLock failed Wang Xiaoqiang
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
