Bruce Hill wrote:
I started working on testing your changes, but it appears you're working
from an earlier copy of TwoDProfileMonitorClass than I have. Would
you mind sending me a copy of the original file you started from, or a
diff?
For the newer version of TwoDProfileMonitorClass, there are
"widthOffsetPvBuff"
and "heightOffsetPvBuf", which I need to replace them with names that we can
use for either XY lineout and ROI, depending on the mode of the
one-click activation.
Thus, I worked from the earlier version of TwoDProfileMonitorClass. The
entire edm TwoDProfileMonitorClass package, including the original file and
a new README, is now posted at
http://www.nsls.bnl.gov/facility/expsys/software/EPICS/
under the "updated S/W". Hope this helps.
Cheers,
Kate
- Re: edm : TwoDProfileMonitorClass : cropping/resizing image Kate Feng
EPICS Base bugs moved to Launchpad Andrew Johnson
Gateways and IOC UAG security: does username to relayed with request? Carl Schumann
<2010>
A patch for libXpm.a (was Re: edm : TwoDProfileMonitorClass : cropping/resizing image) Kate Feng
<2010>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
EPICSv4
IRMIS
Talk
Bugs
Documents
Links
Licensing
