I'm trying to make 2 DXP-XMAP "cards" available via Epics. I have mostly duplicated an almost identical setup that Nino configured for us that was using 1 DXP-XMP. Everything seems to be set up correctly, but I can't see the PV's via caget or an medm interface. Below is the output of running the batchfile sets up the environment and starts cygwin-x86\dxpApp.exe 8element.cmd Any ideas would be very much appreciated. The biggest oddity I'm seeing is that it seems like there are no values for most of the PVs when its restoring from last saved state. Do I need to set these from scratch or are there default values? Please send any responses to ehle@iit.edu as well as the list as I am not a regular subscriber. Output Follows: D:\epics\dxpStandalone_2-10\dxp\2-10\iocBoot\iocXMAPid_med1>REM Tell medm where to look for .adl files. Edit the follow ing line, or comment it D:\epics\dxpStandalone_2-10\dxp\2-10\iocBoot\iocXMAPid_med1>REM out if the environment variable is already set D:\epics\dxpStandalone_2-10\dxp\2-10\iocBoot\iocXMAPid_med1>set EPICS_DISPLAY_PATH=D:\dxp_adls;D:\epics\dxpStandalone_2- 10\dxp\2-10\dxpApp\op\adl;D:\epics\dxpStandalone_2-10\autosave\4-5\asApp\op\adl;D:\epics\dxpStandalone_2-10\mca\6-11\mca App\op\adl;D:\epics\dxpStandalone_2-10\sscan\2-6-3\sscanApp\op\adl;D:\dxp_adls D:\epics\dxpStandalone_2-10\dxp\2-10\iocBoot\iocXMAPid_med1>REM Set up environment form Mingwin D:\epics\dxpStandalone_2-10\dxp\2-10\iocBoot\iocXMAPid_med1>REM DISPLAY=localhost:0.0 D:\epics\dxpStandalone_2-10\dxp\2-10\iocBoot\iocXMAPid_med1>REM XKEYSYMDB=C:\Program Files\Xming\XKeysymDB D:\epics\dxpStandalone_2-10\dxp\2-10\iocBoot\iocXMAPid_med1>REM XLOCALEDIR=C:\Program Files\Xming\locale D:\epics\dxpStandalone_2-10\dxp\2-10\iocBoot\iocXMAPid_med1>REM Start X Server D:\epics\dxpStandalone_2-10\dxp\2-10\iocBoot\iocXMAPid_med1>REM C:\Program Files\Xming\Xming.exe :0 -clipboard -multiwin dow D:\epics\dxpStandalone_2-10\dxp\2-10\iocBoot\iocXMAPid_med1>REM Note that we must use the Windows "start" command or med m won't find X11 dlls D:\epics\dxpStandalone_2-10\dxp\2-10\iocBoot\iocXMAPid_med1>REM start medm -x -macro "P=XMAP_med1:, D=dxp, M=mca" 8eleme nt_dxp.adl D:\epics\dxpStandalone_2-10\dxp\2-10\iocBoot\iocXMAPid_med1>REM Put Cygwin in the path so the EPICS application can find cygwin1.dll D:\epics\dxpStandalone_2-10\dxp\2-10\iocBoot\iocXMAPid_med1>PATH=c:\cygwin\bin; D:\epics\dxpStandalone_2-10\dxp\2-10\iocBoot\iocXMAPid_med1>REM ..\..\bin\cygwin-x86\dxpApp.exe 4element.cmd D:\epics\dxpStandalone_2-10\dxp\2-10\iocBoot\iocXMAPid_med1>..\..\bin\cygwin-x86\dxpApp.exe 8element.cmd < envPaths epicsEnvSet("ARCH","cygwin-x86") epicsEnvSet("IOC","iocXMAPid_med1") epicsEnvSet("TOP","D:\epics\dxpStandalone_2-10\dxp\2-10") epicsEnvSet("SNCSEQ","/cygdrive/d/epics/dxpStandalone_2-10/seq/2-0-12") #epicsEnvSet("EPICS_BASE","/corvette/usr/local/epics/base-3.14.10") epicsEnvSet("ASYN","/cygdrive/d/epics/dxpStandalone_2-10/asyn/4-11beta") epicsEnvSet("MCA","/cygdrive/d/epics/dxpStandalone_2-10/mca/6-11") epicsEnvSet("CAMAC","/cygdrive/d/epics/dxpStandalone_2-10/camac/2-5") epicsEnvSet("DXP","/cygdrive/d/epics/dxpStandalone_2-10/dxp/2-10") epicsEnvSet("CALC","/cygdrive/d/epics/dxpStandalone_2-10/calc/2-7") epicsEnvSet("SSCAN","/cygdrive/d/epics/dxpStandalone_2-10/sscan/2-6-3") epicsEnvSet("BUSY","/cygdrive/d/epics/dxpStandalone_2-10/busy/1-2") epicsEnvSet("AUTOSAVE","/cygdrive/d/epics/dxpStandalone_2-10/autosave/4-5") # Tell EPICS all about the record types, device-support modules, drivers, # etc. in this build from dxpApp dbLoadDatabase("/cygdrive/d/epics/dxpStandalone_2-10/dxp/2-10/dbd/dxp.dbd") dxp_registerRecordDeviceDriver(pdbbase) # Setup for save_restore < ../save_restore.cmd ### save_restore setup # # The rest this file does not require modification for standard use, but... # If you want save_restore to manage its own NFS mount, specify the name and # IP address of the file server to which save files should be written. # This currently is supported only on vxWorks. #save_restoreSet_NFSHost("oxygen", "164.54.52.4") # status-PV prefix #save_restoreSet_status_prefix("xxx:") # Debug-output level save_restoreSet_Debug(0) # Ok to save/restore save sets with missing values (no CA connection to PV)? save_restoreSet_IncompleteSetsOk(1) # Save dated backup files? save_restoreSet_DatedBackupFiles(1) # Number of sequenced backup files to write save_restoreSet_NumSeqFiles(3) # Time interval between sequenced backups save_restoreSet_SeqPeriodInSeconds(300) # specify where save files should be set_savefile_path("autosave") ### # specify what save files should be restored. Note these files must be # in the directory specified in set_savefile_path(), or, if that function # has not been called, from the directory current when iocInit is invoked #set_pass0_restoreFile("auto_positions.sav") #set_pass0_restoreFile("auto_settings.sav") #set_pass1_restoreFile("auto_settings.sav") # load general-purpose interpolation tables with local, user-editable file # (if interp_settings.req is included in auto_settings.req, the next line # will overwrite those restored values) #set_pass1_restoreFile("interp.sav") ### # specify directories in which to to search for included request files set_requestfile_path("./") set_requestfile_path("/cygdrive/d/epics/dxpStandalone_2-10/autosave/4-5", "asApp/Db") set_requestfile_path("/cygdrive/d/epics/dxpStandalone_2-10/calc/2-7", "calcApp/Db") set_requestfile_path("/cygdrive/d/epics/dxpStandalone_2-10/camac/2-5", "camacApp/Db") set_requestfile_path("/cygdrive/d/epics/dxpStandalone_2-10/dxp/2-10", "dxpApp/Db") set_requestfile_path("/cygdrive/d/epics/dxpStandalone_2-10/mca/6-11", "mcaApp/Db") set_requestfile_path("/cygdrive/d/epics/dxpStandalone_2-10/sscan/2-6-3", "sscanApp/Db") #dbLoadRecords("$(AUTOSAVE)/asApp/Db/save_restoreStatus.db", "P=xxx:") save_restoreSet_status_prefix("XMAP_med1:") dbLoadRecords("/cygdrive/d/epics/dxpStandalone_2-10/autosave/4-5/asApp/Db/save_restoreStatus.db", "P=XMAP_med1:") set_pass0_restoreFile("auto_settings8.sav") set_pass1_restoreFile("auto_settings8.sav") # Set logging level (1=ERROR, 2=WARNING, 3=XXX, 4=DEBUG) xiaSetLogLevel(2) xiaInit("xmap8.ini") xiaStartSystem # DXPConfig(serverName, ndetectors, ngroups, pollFrequency) DXPConfig("DXP1", 8, 1, 100) dbLoadTemplate("8element.template") #xiaSetLogLevel(4) #asynSetTraceMask DXP1 0 255 #asynSetTraceIOMask DXP1 0 2 #var dxpRecordDebug 10 ### Scan-support software # crate-resident scan. This executes 1D, 2D, 3D, and 4D scans, and caches # 1D data, but it doesn't store anything to disk. (See 'saveData' below for that.) dbLoadRecords("/cygdrive/d/epics/dxpStandalone_2-10/sscan/2-6-3/sscanApp/Db/scan.db","P=XMAP_med1:,MAXPTS1=2000,MAXPTS2= 1000,MAXPTS3=10,MAXPTS4=10,MAXPTSH=2048") iocInit Starting iocInit ############################################################################ ## EPICS R3.14.10 $$Name: R3-14-10 $$ $$Date: 2008/10/27 19:39:04 $$ ## EPICS Base built Apr 29 2009 ############################################################################ reboot_restore: entry for file 'auto_settings8.sav' reboot_restore (v4.11): entry for file 'auto_settings8.sav' reboot_restore: Found filename 'auto_settings8.sav' in restoreFileList. *** restoring from 'autosave/auto_settings8.sav' at initHookState 5 (before record/device init) *** 1569 PVs had no saved value. reboot_restore: done with file 'auto_settings8.sav' Registered for notification of PCI DMA channel 0: HANDLE 0x564 2010/03/16 15:07:31.901 drvDxp::drvUserCreate, unknown command=ACQUIRING dxpXMAP1:ReadCallback devAsynInt32::initCommon drvUserCreate recDynLinkOut: waiting for CA context reboot_restore: entry for file 'auto_settings8.sav' recDynLinkOut: got CA context reboot_restore (v4.11): entry for file 'auto_settings8.sav' reboot_restore: Found filename 'auto_settings8.sav' in restoreFileList. *** restoring from 'autosave/auto_settings8.sav' at initHookState 6 (after record/device init) *** 1569 PVs had no saved value. reboot_restore: done with file 'auto_settings8.sav' iocRun: All initialization complete
seq dxpMED, "P=XMAP_med1:, DXP=dxp, MCA=mca, N_DETECTORS=8"
SEQ Version 2.0.12: Mon Feb 2 14:57:27 2009
Spawning state program "dxpMED", thread 0x10432b10: "dxpMED"
### Start up the autosave task and tell it what to do.
# Save settings every thirty seconds
create_monitor_set("auto_settings8.req", 30, "P=XMAP_med1:")
### Start the saveData task.
saveData_Init("saveData.req", "P=XMAP_med1:")
saveData: message queue created
saveData: Can't connect to some or all retry PVs
saveData: section [basename] not found
CAS: UDP recv error (errno=Interrupted system call)
epics> Registered for notification of PCI DMA channel 0: HANDLE 0x568
save_restore:connect_list: not all searches successful
save_restore: connect failed for channel 'XMAP_med1:PresetReal'
save_restore: connect failed for channel 'XMAP_med1:PresetLive'
save_restore: connect failed for channel 'XMAP_med1:StatusAll.SCAN'
save_restore: connect failed for channel 'XMAP_med1:ReadAll.SCAN'
save_restore: connect failed for channel 'XMAP_med1:ReadDXPs.SCAN'
save_restore: connect failed for channel 'XMAP_med1:ReadDXPBaselines.SCAN'
save_restore: connect failed for channel 'XMAP_med1:BaselineHistoryTimes'
save_restore: connect failed for channel 'XMAP_med1:TraceWaits'
save_restore: connect failed for channel 'XMAP_med1:EnableClientWait'
save_restore: connect failed for channel 'XMAP_med1:mca1.CALO'
errlog = 611 messages were discarded
save_restore: connect failed for channel 'XMAP_med1:mca4.R3HI'
save_restore: connect failed for channel 'XMAP_med1:mca4.R3IP'
save_restore: connect failed for channel 'XMAP_med1:mca4.R3NM'
save_restore: connect failed for channel 'XMAP_med1:mca4.R4LO'
save_restore: connect failed for channel 'XMAP_med1:mca4.R4HI'
save_restore: connect failed for channel 'XMAP_med1:mca4.R4IP'
save_restore: connect failed for channel 'XMAP_med1:mca4.R4NM'
save_restore: connect failed for channel 'XMAP_med1:mca4.R5LO'
save_restore: connect failed for channel 'XMAP_med1:mca4.R5HI'
save_restore: connect failed for channel 'XMAP_med1:mca4.R5IP'
save_restore: connect failed for channel 'XMAP_med1:mca4.R5NM'
save_restore: connect failed for channel 'XMAP_med1:mca4.R6LO'CAS: UDP recv error (errno=Interrupted system call) CAS: Client accept error was "Interrupted system call" eAS: Client accept error was "Interrupted system call" CAS: UDP recv error (errno=Interrupted system call) Thanks in advance! David.
| ANJ, 02 Sep 2010 |
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
