g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Subject: ArchiveViewer doen't connect
To: tech-talk@aps.anl.gov
Date: Thu, 24 Dec 2009 16:12:17 +0100
Hello !
I've been trying to make the ArchiveViewer work, but no such luck. I have managed to set up the ArchiveDataServer correctly, or at least I think so. When I connect to the server with ArchiveDataClient.pl I receive the channel list when I use the -l handle. But whenever I use the -i handle to receive the server information, I get the: 500 Internal server error. Anyway, when I try to connect to the server via ArchiveViewer I always get the same error like when using -i handle with ArchiveDataClient.pl - Internal Server Error. So, my question is:
- Does it even look like the server is set up correctly ( i get the channel list with even the right timestamp )
- I cannot get the server info using ArchiveDataClient, but get the channel list
- I cannot connect to server using ArchiveViewer
I hope i gave enough info so you can point me into the right direction.
Thanks in advance and merry christmass.
Blaz
Prev: Re: Epics in Pen drive Umashankar Panda
Next: how to use scalcout record in streamdevice? Silver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Prev: EPICS Codeathon at Diamond, 24-28 May Andrew Johnson
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
