g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Subject: Re: makeBaseApp -t ioc missing Makefile
From: Patrick Thomas <thomas_p@ligo-wa.caltech.edu>
To: Zhichu Chen <zhichu.chen@gmail.com>, tech-talk@aps.anl.gov
Date: Fri, 18 Sep 2009 20:40:37 -0700
Yes, there is a Makefile there.
-Patrick
Zhichu Chen wrote:
Are you sure your "base" is made successfully without any errors? You
can check your base/templates/makeBaseApp/top/iocApp to see if there's
Makefile there. makeBaseApp.pl just copy the files and do some macros
replacements I think.
On Sat, Sep 19, 2009 at 8:42 AM, Patrick Thomas
<thomas_p@ligo-wa.caltech.edu> wrote:
and I have 3-14-11 instead of 3-14-11-asdl
Eric Norum wrote:
Seems to work here:
norume 233>
/usr/local/iocapps/R3.14.11/base/3-14-11-asd1/bin/darwin-x86/makeBaseApp.pl
-t ioc blah
norume 234> ls -R
Makefile    blahApp        configure
./blahApp:
Db        Makefile    src
./blahApp/Db:
Makefile
./blahApp/src:
Makefile    blahMain.cpp
./configure:
CONFIG        Makefile    RULES        RULES_DIRS
CONFIG_SITE    RELEASE        RULES.ioc    RULES_TOP
On Sep 18, 2009, at 5:15 PM, Patrick Thomas wrote:
I was trying to run makeBaseApp -t ioc with epics 3-14-11, and I noticed
that it did not put a Makefile in the directory. It only creates the
application directory and the configure directory. Is this correct?
Thank you,
Patrick
Re: makeBaseApp -t ioc missing Makefile Zhichu Chen
makeBaseApp -t ioc missing Makefile Patrick Thomas
Re: makeBaseApp -t ioc missing Makefile Eric Norum
Re: makeBaseApp -t ioc missing Makefile Patrick Thomas
Prev: Re: makeBaseApp -t ioc missing Makefile Patrick Thomas
Next: Re: makeBaseApp -t ioc missing Makefile Zhichu Chen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
