The following message appears when building EPICS base 3.14.11 with INSTALL_LOCATION=<some_path_different_to_top> in configure/ CONFIG_SITE. This problem appears in darwin-x86 (MacBook Pro) and linux-x86 (Linux debian etch). In this case, TOP=/opt/epics/3.14.11/ base and INSTALL_LOCATION=/opt/epics/3.14.11/install $ cd /opt/epics/3.14.11/base $ make ... make -C ./softIoc install perl /opt/epics/3.14.11/install/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../../.. mkdir O.Common make -C O.darwin-x86 -f ../Makefile TOP=../../.. T_A=darwin-x86 install perl /opt/epics/3.14.11/install/bin/darwin-x86/makeIncludeDbd.pl base.dbd dlload.dbd system.dbd ../O.Common/softIocInclude.dbd Expanding dbd /opt/epics/3.14.11/install/bin/darwin-x86/dbExpand -I . -I .. -I /opt/ epics/3.14.11/install/dbd -o ../O.Common/softIoc.dbd ../O.Common/ softIocInclude.dbd Installing created dbd file /opt/epics/3.14.11/install/dbd/softIoc.dbd Installing db file /opt/epics/3.14.11/install/db/softIocExit.db mkdir /opt/epics/3.14.11/install/db perl ../makeInstallDir.pl /opt/epics/3.14.11/install > ../O.Common/ epicsInstallDir.h Can't locate EPICS/Path.pm in @INC (@INC contains: /opt/epics/3.14.11/ base/src/softIoc/../../lib/perl /Library/Perl/Updates/5.8.8 /System/ Library/Perl/5.8.8/darwin-thread-multi-2level /System/Library/Perl/ 5.8.8 /Library/Perl/5.8.8/darwin-thread-multi-2level /Library/Perl/ 5.8.8 /Library/Perl /Network/Library/Perl/5.8.8/darwin-thread- multi-2level /Network/Library/Perl/5.8.8 /Network/Library/Perl /System/ Library/Perl/Extras/5.8.8/darwin-thread-multi-2level /System/Library/ Perl/Extras/5.8.8 /Library/Perl/5.8.6 /Library/Perl/5.8.1 .) at ../ makeInstallDir.pl line 15. BEGIN failed--compilation aborted at ../makeInstallDir.pl line 15. make[3]: *** [../O.Common/epicsInstallDir.h] Error 2 make[2]: *** [install.darwin-x86] Error 2 make[1]: *** [softIoc.install] Error 2 make: *** [src.install] Error 2 Any help will be appreciated. Thank you. Juan Carlos. ---------- Juan Carlos Guzman Software Engineer CSIRO Australia Telescope National Facility (ATNF) P.O.Box 76, Epping NSW 1710, Australia Phone: +61 2 9372 4457 Fax: +61 2 9372 4310 Email: Juan.Guzman@csiro.au
| ANJ, 02 Sep 2010 |
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
