g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Subject: Access to IO registers from user-space in recent Linux versions
To: "tech-talk" <tech-talk@aps.anl.gov>, <beamline_controls@aps.anl.gov>
Date: Thu, 9 Jul 2009 13:08:06 -0500
Folks,
I have an EPICS application that directly accesses the parallel port (EPP) registers from user space on Linux.  This is to communicate with an XIA Saturn spectroscopy module.
In order versions of Linux this worked fine if I ran the application as root, or by calling iopl(3) as root before exec-ing the EPICS application.
I am now trying to run this under a recent Linux (Redhat Fedora) version
baja:~>more /proc/version
Linux version 2.6.26.8-57.fc8 (mockbuild@x86-4.fedora.phx.redhat.com)
(gcc version 4.1.2 20070925 (Red Hat 4.1.2-33))
#1 SMP Thu Dec 18 18:59:49 EST 2008
The EPICS IOC now crashes with a segmentation fault when trying to access the EPP port, even when running as root, and the following entry appears in /var/log/messages
Jul  9 11:43:44 baja kernel: dxpApp[27837] general protection ip:80a90a6 sp:ff8ea8ac error:0 in dxpApp[8048000+1f7000]
Does anyone know what one needs to do in recent Linux versions to get access to the IO registers from user-space?
Re: Access to IO registers from user-space in recent Linux versions Till Straumann
Re: Access to IO registers from user-space in recent Linux versions John Sinclair
Re: Access to IO registers from user-space in recent Linux versions J. Lewis Muir
Prev: Re: Detecting data lost from a subscriber Andrew Johnson
Next: Re: Access to IO registers from user-space in recent Linux versions Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Prev: RE: compiled asyn-4.10 with ipac-2.10 Mark Rivers
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
